Recomendations for 4agze oil pressure solution
Postby beeker » Sat Dec 20, 2008 9:01 pm
I assume the easiest way is to buy an 'oil filter sandwich plate/pickup' for the oil pressure guage ?
Anyone got a recommended brand and supplier ?
or alternative ?
For a AE101 4agze (in my AE86)
PS How hard are they to fit? I'm a bit of an 'office worker' :)
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby gepsk8 » Sat Dec 20, 2008 9:26 pm
u running p/s? if not remove orginal gauge sender and replace with what sender u want to run
O272754663
gepsk8
Postby mr30%jr » Sat Dec 20, 2008 9:30 pm
if using original sender (ae86 gauge) ( ae85 switch) either get a brass T or replace it.
its on the exhaust side near the front of the motor
mr30%jr
Postby CAMB01 » Sun Dec 21, 2008 12:51 am
mr30%jr wrote:if using original sender (ae86 gauge) ( ae85 switch) either get a brass T or replace it.
What ever you do dont use a brass T, they break very easily, especially if this is a race car, vibrations cause them to break. Steal or the like is the better option.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby 85AW20v » Sun Dec 21, 2008 1:01 am
You need to decide first if you're going to use a mechanical or electronic gauge. Mechanical will require a tee if you still want to run the original warning light/dash gauge or a 25lb warning light - to give you time to shut it down if pressure is low - instead of the old dash light. Electronic gauge you'd probably do away with the original light/gauge and screw the new sender unit in, in place of the original.
See ya
Simon
85 MR2 20v
85AW20v
