xsspeed wrote:Negs that I can see
Extra piping (air and oil)
Turbo's get hot, dont park over dry leaves
Need to change filters heaps
What happens when its wet/puddles?
Turbo's get hot, close to fuel tank
Larger debris could easily take out a turbo, filter, oil line etc
Probably suit a mid/rear mounted engine setup better?
Adydas wrote:one negative no one seems to have considerd is the theft risk..
If its only bolted on using the same tools as removing the mags you could potentially (unless its welded) remove the turbos and get away with a steal mish on one.
Not likely i wouldnt imagine , to time consuming and a risk etc but still more possible than the likelyhood of somthing taking your turbo from the engine bay..
