l1ttle_d3vil wrote:the battery has been flat a couple of times (not dead though, just enough to not crank over) but that would've been 6 months ago and never had issues since.
rollaholic wrote:you'll only get 13- 14v with the car running
l1ttle_d3vil wrote:rollaholic wrote:you'll only get 13- 14v with the car running
yeah the alternator is putting out 14.4v when running i think, and 13.4 at the battery. will give it a charge up and see how I go. must be a sign I need to drive it more
BZG|Bling wrote:l1ttle_d3vil wrote:rollaholic wrote:you'll only get 13- 14v with the car running
So are you losing 1V between alt and battery?
and a dead batt wont render a jump pack useless
pc wrote:rollaholic wrote:you'll only get 13- 14v with the car running
Yes it can. A really dead/bad battery can end up sucking all the juice and there isn't enough to start the car.
Had it happen a few times.
plasticdash wrote:pc wrote:rollaholic wrote:you'll only get 13- 14v with the car running
a decent commercial type jump pack (ie 1900 Amp plus) will not be worried by a fully dead 13 plate battery, although smaller cheap packs will fall over, and some of those massive Beemer/merc batteries can put a load on
good (although possibly dodgy) trick is to disconnect the battery earth, chuck the jump pack positive on battery pos teminal and jump pack neg to a good earth (which takes the battery draw out of the circuit) and start. then chuck the earth lead back on the batt and then remove j/pack
