Who sells these connectors? (Defi)
Postby MrOizo » Mon Feb 02, 2009 2:57 pm
Does anyone know who sells these connectors?
Tried RS Components and Jaycar but nothing...
Need to extend a cable and would like to make my own first. Coud extend my exising one but might look a little ghetto :o
MrOizo
Toyspeed Legend
Postby Stu- » Mon Feb 02, 2009 4:09 pm
Cut and solder in a new section then re heat shrink?
Project Thread
Stu-
Postby MrOizo » Mon Feb 02, 2009 4:22 pm
I did that with the last controller. Dont want to this time and make my own one up.
Think I might be doing that instead of paying the $50 for a new one :o
MrOizo
Toyspeed Legend
Postby Boosted_162 » Mon Feb 02, 2009 5:59 pm
I think i got a spare defi wire lying around you can have to cut up if you wish...
Postby MrOizo » Mon Feb 02, 2009 6:56 pm
Boosted_162 wrote:I think i got a spare defi wire lying around you can have to cut up if you wish...
Ooooo yes please!!!
See you friday? :P
MrOizo
Toyspeed Legend
Postby Emperor » Mon Feb 02, 2009 7:17 pm
On same note -
I'm after the smaller plugs, that you plug the gauge into the controller with..
Emperor
Postby MrOizo » Mon Feb 02, 2009 7:47 pm
Emperor wrote:On same note -
This is the one. goes from the controller to the guage. you dont mean the sensor ones do you?
MrOizo
Toyspeed Legend
Postby soopachargen » Mon Feb 02, 2009 7:51 pm
you cant de-pin the plug and solder the new wire direct to the pin can you?
When in doubt, down and out.
soopachargen
Postby Emperor » Mon Feb 02, 2009 7:56 pm
ah yes, that/s the one I meant, really small buggers
Emperor
Postby neo » Mon Feb 02, 2009 7:59 pm
How fancy do you want to be? Will the standard cd audio to motherboard connector do?
neo
Postby MrOizo » Mon Feb 02, 2009 8:45 pm
soopachargen wrote:you cant de-pin the plug and solder the new wire direct to the pin can you?
I tried re-soldering it but my iron is a little big and made a mess filling in the hole.
Would prefer getting aother cable and extending it.
Cheers.
MrOizo
Toyspeed Legend
Postby Boosted_162 » Mon Feb 02, 2009 9:01 pm
All yours if you want it Adrian....Ill probably be there on friday :)
Postby MrOizo » Mon Feb 02, 2009 9:37 pm
Much appreciated :D:D:D:D
If you cant make it, i'll come get it :P
MrOizo
Toyspeed Legend
