Has anyone rebuilt a W5X box before?
Postby cat007 » Mon Dec 22, 2008 7:38 am
I put mine all together after replacing all bung bearings - but I have a circlip/snap ring left over!!!!
And I cant for the life of me remember where it went
Its not like any of the other snap rings where the tips are pointy. This one looks like this:
Bit of a long shot - but does anyone have any suggestions or idea's where this might go?
Oh yeah - and as you can see there is a wear mark on the outside of one side, and on the other side, the wear mark is on the inside......Not sure if that means anything.....
Postby postfach » Mon Dec 22, 2008 9:51 am
is it anywhere in here?
postfach
Postby cat007 » Mon Dec 22, 2008 9:57 am
Well that's the strange thing - I don't think it is
33103G (next to speedo drive gear - right hand side in the middle of that drawing - looks like it could be it - but that just doesnt make sense - but in real life that bearing doesn't have a circlip slot
I've gone over that drawing - and the others - and I just cant figure it out.
Everything's in place and "tight"
I just don't see where it could have gone.
Postby Bazda » Mon Dec 22, 2008 11:39 am
looks like 33311G to me.
And it def looks like it holds a bearing in place. (big bearing)
Postby cat007 » Mon Dec 22, 2008 11:43 am
Bazda wrote:looks like 33311G to me.
nah its not as big as that.
on the front of the gearbox - there's a BIG bearing for the main input shaft, then there's a smaller one under it - it fits around the smaller one - but its too "thin" - and I've already got one for that smaller one......
Postby Jason T » Mon Dec 22, 2008 12:13 pm
I have just reasembled a W55
That cirlip ring is front lower lay shaft behind steel cover in bellhousing
Looks to be part # 33411D
Fixing Toyota's since '87
Jason T
Postby cat007 » Mon Dec 22, 2008 12:16 pm
Jason T wrote:I have just reasembled a W55
Ah - no see its not - I already have that one in place......
Postby Bazda » Mon Dec 22, 2008 1:06 pm
I suggest you pull the box apart and start again.
As this part is left over so it defiantly goes in there somewhere
Postby cat007 » Mon Dec 22, 2008 2:18 pm
Bazda wrote:I suggest you pull the box apart and start again.
*sigh* was "really" hoping to have the car going this week sometime
Postby Jason T » Mon Dec 22, 2008 2:37 pm
Then have fun pulling it apart again
Jason T
Postby cat007 » Mon Dec 22, 2008 3:22 pm
*grumble grumble*
Postby AE86less » Mon Dec 22, 2008 7:35 pm
cat007 wrote:
*grumble grumble*
:lol:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Lloyd » Tue Dec 23, 2008 12:08 am
Please refer to the following link, rule 57
http://www.urbandictionary.com/define.p ... man%20code
"57. You have not made any mistake if you find that there are extra pieces after reassembling or assembling an object. In fact, you have just found a way to make that object more efficient. "
Postby blackmk3 » Tue Dec 23, 2008 8:17 am
You will be alright just don't worry about it, the 1ggte doesn't make enough torque for it to be a problem :lol: haha
Certainly looks like its for one of the big bearings, and if there's one already there then your missing one from some ware else
Mk3 MA70 Supra
blackmk3
Postby cat007 » Tue Dec 23, 2008 8:20 am
blackmk3 wrote:You will be alright just don't worry about it, the 1ggte doesn't make enough torque for it to be a problem :lol: haha
haha - yeah yeah :P :P
Well I'm sure its important - so when I get home tonight I'll have another look/play.
Postby cat007 » Sat Feb 07, 2009 4:11 pm
well I gave up wondering any more
Put gearbox back together and put it in the car
Went for a test drive just now - seems ok - but wont go into 3rd from 2nd sometimes......
I'll take it for a few more easy drives just to let everything settle
Postby sleeektoy » Sun Feb 08, 2009 11:12 am
theres a "shim" type circlip that sits between the 3rd gear syncro hub assy and the shoulder it sits against. this reduces end float in the 3rd gear assy.
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
Postby cat007 » Sun Feb 08, 2009 11:18 am
sleeektoy wrote:theres a "shim" type circlip that sits between the 3rd gear syncro hub assy and the shoulder it sits against. this reduces end float in the 3rd gear assy.
oh so NOW you tell me lol
Well hopefully its not too important LOL
