Which is best place to get 10-11mm Aluminuim plate?
Postby MrOizo » Thu Feb 12, 2009 2:23 pm
After some Aluminuim plate about 10-11mm thick.
Looking to have it 400mm diameter.
Soooo... were you guys reckon?
Ullrich, Nalco?
MrOizo
Toyspeed Legend
Postby TRD Man » Thu Feb 12, 2009 2:29 pm
I would be looking for an aluminium engineering place that may sell you an offcut.
TRD Man
Postby strx7 » Thu Feb 12, 2009 2:39 pm
10mm thick alloy gets really pricey
Postby MrOizo » Thu Feb 12, 2009 2:44 pm
strx7 wrote:10mm thick alloy gets really pricey
Yeah thats what i thought. Its for the road testing gear that i have and the steel one is swinging too much when i am driving.
Will try a place for off cuts, cheers TRD Man.
MrOizo
Toyspeed Legend
Postby Malcolm » Thu Feb 12, 2009 5:21 pm
talk to Nalco in East Tamaki, they have offcuts that they sell - they still charge you full price for material but don't charge a cutting fee. For the size you're talking about, I'd expect it'll cost around $70-80 if the price hasn't changed in the last 6 months. Also, it'll be a square/rectangle, if you want it round you'll have to cut it/turn it afterwards. I could probably do that for you on the mill at our workshop for a small box o' beer
Postby evil_si » Thu Feb 12, 2009 5:48 pm
could also try
one stop cutting shop in silverdale, they would be able to supply and cut a piece to the size you need
evil_si
Postby Stu- » Thu Feb 12, 2009 6:16 pm
As evil_si has said - talk to Kevin, they have 10mm and 12mm in stock.
Project Thread
Stu-
Postby MrOizo » Tue Feb 17, 2009 11:58 pm
Thanks for reccommending "One Stop Cutting Shop" guys.
Getting the plate sorted for tomorrow. 300mm dia with 1" hole in the middle on 12mm Aluminium plate. Water jet cut i am thinking for $60... not too bad!
Malcolm, now i know you have access to a workshop i might ome see you some time in the future. always needing things fabbed up
Cheers!
MrOizo
Toyspeed Legend
Postby Malcolm » Wed Feb 18, 2009 4:08 pm
I have access to a workshop, but I don't have a huge amount of time so I can probably help with the occasional small job, but nothing big.
Who's doing the waterjet cutting?
Postby evil_si » Wed Feb 18, 2009 5:39 pm
kev at one stop cutting shop, use to be north shore water cutting
evil_si
Postby cat007 » Wed Feb 18, 2009 8:02 pm
without jumping on your thread too much - I'm also after a bit of alloy. Basically I want to put about a ~10mm spacer on top of the spring (between spring and top hat) to raise the front of the car a little.....
Would alloy be best for this? or would it not matter what material I use?
Users browsing this forum: No registered users and 26 guests
