Shipping, anyone work for NZPost?
Postby FST4RD » Fri Feb 27, 2009 4:59 pm
I need to get a Starion bonnet from Chch to Auck.... I know there's a million subjects about this on this site.... But....
Mainfreight quoted $102 door to door... not to bad.
Went on to the NZPost website and for a 1380mm x 1110mm x 80mm x 15Kg parcel (just guessing the weight) they quoted:
ParcelPost™ Tracked
1. Zonal Postage Only
Nationwide 1 - 3 Working Days $50.50
So if I bubble wrap it up, rock on down to the NZpost shop they're going to be fine with this right? I haven't found anything that says that they won't send car parts, well bonnets anyway....
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby DeeCee » Fri Feb 27, 2009 5:14 pm
Give them a bell, but if it falls within their parameters and doesn't pose a hazard then it should be fine.
GT Four Adovansu
DeeCee
Postby rollaholic » Fri Feb 27, 2009 5:22 pm
you might find your weight guess a little light
Postby Adamal » Fri Feb 27, 2009 5:41 pm
rollaholic wrote:you might find your weight guess a little light
Yea, thats the first thing that popped into my head too...
Postby Mr Revhead » Fri Feb 27, 2009 5:54 pm
waaaaaaay too big for post
Postby FST4RD » Fri Feb 27, 2009 5:58 pm
Mr Revhead wrote:waaaaaaay too big for post
I thought so to... but according to the website it's ok.....
FST4RD
How much an average bonnet weigh?
FST4RD
Postby FST4RD » Fri Feb 27, 2009 6:13 pm
Apparently the bonnets weigh about 20kg's about...
Even in the rate finder with 1380mm x 1110mm x 80mm x 25kg's it still works out at $50.50.....
Guess with some bubble wrap and cardboard and tell them it's a huge picture I should be fine :lol:
FST4RD
Postby DeeCee » Fri Feb 27, 2009 6:20 pm
the website is an estimate only. You need to call a post shop and see what they will and won't take to confirm if you can or can't put the bonnet through at that rate.
If you know someone with a business, ask them if they have a courier service and get a quote from them.
For my business I use a couple of companies for logistics. One is day to day, one is for larger items.
GT Four Adovansu
DeeCee
Postby FST4RD » Fri Feb 27, 2009 6:26 pm
DeeCee wrote:the website is an estimate only. You need to call a post shop and see what they will and won't take to confirm if you can or can't put the bonnet through at that rate.
Well it's got to be sent so have to package it up regardless....
So will package it up, there's a postshop just round the corner so will pop round there with it and ask them, if not will take it to mainfreight.
FST4RD
Postby B1NZ » Fri Feb 27, 2009 6:32 pm
I was under the impression that it you could fit it through the door you could post it, I remember and ad on telly a few years back, Things may have changed?
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby FST4RD » Fri Feb 27, 2009 6:34 pm
Well hopefully it will be fine and save this guy a few bob in the long run.... I won't tell them what it is and lie through my teeth if they ask... :lol:
FST4RD
Postby Mr Revhead » Fri Feb 27, 2009 6:48 pm
Postby FST4RD » Fri Feb 27, 2009 6:53 pm
No it's not
http://www.nzpost.co.nz/NZPost/Template ... HINT=Guest
Put in 1380mm x 1110mm x 80mm x 25kg's and it says it's fine....
Thats only courier pacages maybe?
FST4RD
Postby FST4RD » Fri Feb 27, 2009 6:55 pm
Oh and it's going Chch to Aucks....
FST4RD
Postby Mr Revhead » Fri Feb 27, 2009 7:08 pm
**Volumetric weight calculation:
(Height (m) x length (m) x width (m)) x 200 = volumetric weight (kg)
1.380 x 1.11 x 0.08 = 0.123 x 200 = 24.5
plus packaging....
if you can get it wrapped staying under that, you still have to get past the counter nazis! i have had things refused that according to their website are fine
Postby FST4RD » Fri Feb 27, 2009 7:11 pm
Yeah your right... so have I... just hope I get the right attendant at the right time!
FST4RD
Postby fangsport » Fri Feb 27, 2009 7:18 pm
Fastway.
had to send a door to Napier.
$100 + through Mainfreight, McDowells etc (Napier not good, off SH1).
Fastway under $50
fangsport
Postby FLAWLES » Fri Feb 27, 2009 8:18 pm
no its not
most courer out fits take anything as long as its ticketed correctly and fits in there van it will be sent
talking nzc and c post
i can send a 25kg 2.3m x 1.5m x 80mm curved tractor glass door around nz for less then $80
bonnet is easy but it will be pricey doing things this way
but fast ways or post haste will be your best bet,t
i would still stick with mainfreight tho, may take a wee while ( 3 to 5 working days ) but its going to be cheaper
FLAWLES
Postby Bling » Fri Feb 27, 2009 9:58 pm
Drop it at a mainfrieght depot and get them to pick it up for a local depot to save money.
I just got a set of rims with tyres 0.16m3 60kg Nelson to chch next day for $50.
(just an example)
