i can't measure it, but I'd guess its around 0.5 - 1mm side to side and end to end movement. fins don't rub on the compressor or anything.
it blew a bit of smoke previously, and some oil in the compressor inlet.
on the weekend i stupidly managed to get the timing 180º out which made a loud noise out the exhaust
also, im running the t25g on 12psi (hits around 15 before coming down), if I get it rebuilt is it likely to handle 12psi reliably? or should I not bother and swap it for a t28?
-matt
