spacers
Postby rollaholic » Mon Mar 09, 2009 4:36 pm
have rocked slipons on heaps of cars, never had a problem
Postby Distrb » Mon Mar 09, 2009 4:39 pm
read http://www.lvvta.org.nz/stdWheels&Tyres.pdf
in particular sections 2.5(1); 2.5(2); 2.5(3) 2.5(7)
also sections impacted by spacers 2.2(8)
In short: Spacers or adaptors must be certified, no matter how thick. They must also be secured to the hub or wheel face, no matter how thick
Sure people have got away with all sorts of things in all sorts of places (i've even seen people get away with certing slip on spacers). But if you want to know what the current official documents on the topic say, then read the above link.
Distrb
Regular Poster
Postby bluemaumau » Mon Mar 09, 2009 9:51 pm
good info disturb.
are ae101 hubcentric diameter 73mm
im away from the car tonight
Postby bluemaumau » Fri Mar 13, 2009 4:35 pm
so the hub centric ring should fit the hub or wheel
hub is 54mm and rim is 72mm
im guessing the hub ..as it then makes it, i guess, more part of the hub?
Postby postfach » Fri Mar 13, 2009 4:41 pm
It should fit both, the spacer should be snug on the hub, the wheels should be snug on the spacer.
Most people overlook this when fitting aftermarket rims, but you'll notice a factory rim always fits tightly over the hubcentric ring on the hubs of the car they came out on.
postfach
Postby bluemaumau » Fri Mar 13, 2009 4:58 pm
i wouldnt imagine they make them like that.
so should i go hub or rim?
Postby Mr.Phreak » Fri Mar 13, 2009 5:55 pm
They should be the same as the hub, and from the sounds of it, your wheels need some spigot rings
Mr.Phreak
Postby postfach » Fri Mar 13, 2009 6:15 pm
Yeah you can buy rings to fit between your hub/spacer and rim from most wheel/tire shops
postfach
Postby callum » Sun Mar 15, 2009 8:33 pm
my corolla is certed for slip on spacers
callum
