9s should come soon, the funny thing was i over took a v8 that ran a 9.8 but as soon as i hit my rev limiter he over took me dam rev limiter lol.Dell'Orto wrote:Awesome stuff, roll on 9's
As soon as we can sort out are rev limiter problem we will be into the 9s and for this season my goal is a 9.5sec run.2jayzgte wrote:Its been quite awhile since a Supra has run in the 9s good going i'm pretty sure its just around the corner.....
audi man wrote:yes still running 98 pump gas.Lith wrote:Nice work man, good seeing this getting some sharp times! Is that still on pump gas?
No nos yet but when the rev limiter fixed then the nos will be usedLith wrote:audi man wrote:yes still running 98 pump gas.Lith wrote:Nice work man, good seeing this getting some sharp times! Is that still on pump gas?
Thats nuts, well done! Is there any Nitrous Oxide usage?
Snaps wrote: remove the rev limiter
My car already max out at about 145mph and it was like hitting a brick wall thats why it was dropping my speed any were from 130mph up to 138mph i need to get around 155mph, looking at my half track speed that was 119mph i should been close to 150mph.1hypo3 wrote:Change your diff ratio and then use the nos to compensate, then you would be in the 140s mph maybe hit 150
The diff i am running is a 3.7 and i cannot find a supra diff lower than that.the fallen303 wrote:what diff you running john? can probably raise the limiter another 500-1k, but that wouldn't gain you that much by the end of the track, and if you're already hitting it as it is, by the time you use nos as well, just raising the limiter may not help you enough.
