Help with AVS S5 programming
Postby astrae » Fri Mar 20, 2009 8:34 pm
Hi
Can anyone help me get a copy of the programable features instructions of a new S5 alarm. They aren't in the owners manual.
I want to know how to change the inbuilt turbo timer settings. The installer has turned it on and I want it off.
Thanks
astrae
Postby Mr.Phreak » Fri Mar 20, 2009 8:46 pm
XS1V might tell you if he's feeling generous :lol:
Mr.Phreak
Postby phraza » Fri Mar 20, 2009 9:14 pm
yo
any of this help?
http://www.avs.net.nz/troubleshooting/i ... _s5_s4_s3/
i screwed up my S5 once, not sure what buttons i pressed, but i just rang the AVS headoffice in Albany in auckland... not sure of their number
http://www.avs.net.nz/contact_us/
maybe?
2WD 06 Hilux
phraza
Postby AJz » Fri Mar 20, 2009 9:40 pm
i had a copy but cant find it atm, ill keep looking
If its on atm, its wired up that way.
If you turn it off through the manual, its gonna run for about 5 seconds anyway.
Some stupid thing they designed. If you want it completely off, the ignition needs to be wired slightly differently.
< ex installer services
*EDIT* found it, whats your email dude
I had vtax :(
AJz
Postby astrae » Sat Mar 21, 2009 7:40 am
pm'd thanks
astrae
Postby XS1V » Mon Mar 23, 2009 9:55 am
astrae - As AJz said it will run on for a bit still as you have it has been wired through the immobilizers to run the t/t. The reason it does this (its not some stupid thing we designed 8) ) is so that in normal conditions when you are starting the car, the immobilisers stay closed so that the ignition and fuel pump don't drop away, would have a bit of trouble starting it otherwise :wink:
phraza - You would have talked to me :) our number is 09 4768052
Mr.Phreak - I'm always in a generous mood 8)
Anyways, to change turbo timer run times do the following:
Hop in the car and shut the door as well as having boot and bonnet closed
Arm then disarm the alarm
Turn the ignition to ON
Press the boot pop button (left hand button on torch remotes) 16 times, it will beep for each press, if not start again.
Now turn the ignition off, the siren will beep
Press the boot pop button, the alarm will beep out what it is set on
1 beep = 1min, 2 beep = 2.5mins, 3 beeps = 5mins, 4 beeps = 0mins
Press the boot pop button again to cycle through till you have the desired setting
Turn ignition on then off again to exit the mode
That will sort it for you :) You always have the option of just shutting it down early via the boot pop button anyways remember
Brad
ST205 Group A Rallye #2363
XS1V
Postby phraza » Mon Mar 23, 2009 9:59 am
haha sweet, ill know who to come to next time i got a problem :D
2WD 06 Hilux
phraza
Postby AJz » Mon Mar 23, 2009 1:48 pm
XS1V wrote:(its not some stupid thin we designed 8) )
:P
I had vtax :(
AJz
Postby astrae » Mon Mar 23, 2009 5:58 pm
Thanks Brad. Yeah it does run for about 10 seconds. Least I know how to change it now
astrae
