Isuzu Giga - Translator
Postby RedMist » Sat Mar 21, 2009 4:38 pm
Guss wrote:not much more help but both the buttons are something to do with lights
It's a start. There are an absoulte tonne of lights on this thing, and most on the gullwing, have the wiring ripped out.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby postfach » Sat Mar 21, 2009 5:23 pm
Um, something one of our drivers was saying to me the other day when he noticed a light out on the truck we were using was that if the lights are fitted, they have to work, might be something to check up on, potential COF issue?
postfach
Postby 85AW20v » Sat Mar 21, 2009 10:26 pm
Could they be for night park lights that a lot of trucks have - just turn on the rearmost red taillight on each side?
See ya
Simon
85 MR2 20v
85AW20v
Postby Akane » Sun Mar 22, 2009 12:16 am
Adjustable type Change lever.
Neutral position adjustment
1) Ring levitate up (Do 1)
2) desired position (3 steps) then do (dunno) with the ring), and lock) (do 2)
caution:
Neutral Position adjustment, the car must be stopped, Parking brake must be applied, gear must be in Neutral
Adjusting when car is moving must not do, please.
and those 2 buttons are some kind of light switch.
Postby GX61 Mark II » Sun Mar 22, 2009 1:48 am
Akane wrote:Adjustable type Change lever.
caution:
Spot on.
1) Lift up the ring (image 1)
2) Select the desired position (3 steps) then release the ring (image 2) and lock in place.
The buttons are for light switches for the width of the truck so should be either a light on the left and right corners of the front fender or lights down the length of the truck down the left and right sides.
GX61 Mark II
Postby RedMist » Sun Mar 22, 2009 9:25 pm
Brilliant, thanks gentlemen!
RedMist
Postby sprey1661 » Sun Mar 22, 2009 9:26 pm
RedMist wrote:
sprey1661 wrote:is it an 8x4? ill compare your pic to the difflock button on our nissan.
just remembered i was suppost to post back how we wired in the stereo on it. many months ago. Sorry
I've now got to repeat the task, after failing on the Hino I now have to wire a Stereo on the Isuzu!!!
It's one of those weird ar*e 6x2's with twin steer. But has a second twin drive bogy in the box for installation at some point in time.
Haha i think they call them chinese sixs. could be wrong tho.
Double steer and single axle at the back. Seen a few of imported tankers are like that.
Twin drive boggy :S ???
sprey1661
Postby RedMist » Sat Mar 28, 2009 8:48 pm
Bugger, looks like I'll have to trace it with a multimeter..... Tried every combination of switch and lights and the two switches don't appear to do anything. It could be part of the dozen or so wires that's still hanging loose from the bottom of the gull wing!
RedMist
Postby mjrstar » Sat Mar 28, 2009 9:18 pm
RedMist wrote:Bugger, looks like I'll have to trace it with a multimeter..... Tried every combination of switch and lights and the two switches don't appear to do anything. It could be part of the dozen or so wires that's still hanging loose from the bottom of the gull wing!
have you tried these switches at night time if they are clearance lights they may be attached to a lux meter which will mean they come on after dark?
ie: won't waste battery during daylight hours...
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby RedMist » Sat Mar 28, 2009 10:33 pm
Nice try....
But no. I tried it.
The switches have an inbuilt LED, they are only getting power when the key is on.
RedMist
Postby Cakky » Sun Mar 29, 2009 11:23 am
I'd say they do nothing, probably were for previous chassis whatever sort of body it may have had on it in Japan, Possibly interior lights for a box body or something similar
Cakky
