Mr Revhead wrote:see the notch in the side of the blacktop rod?
i think that allows more oil past it than the holes in the other versions of the 4age rod.
fivebob wrote:Mr Revhead wrote:see the notch in the side of the blacktop rod?
Why would that matter?
Oil is pressure feed through the crankshaft. As long as there is the same clearance and the bearings are the same size, then the oiling should be the same.
Mr Revhead wrote:yep, but my theory is that notch allows more oil through it, therefore less resistance to the oil passing through there which decreases the pressure in the journal.
and when that happens with an instance of lower than normal pressure, say surge from hi rpm corner or low sump volume (coz lets face it, theres bugger all in there) they are more susciptible to a run bearing.
also that notch is the only difference in the oil system of the blacktop
The purpose of this study is to analyze con-rod bearing lubrication under reduced oil supply rate conditions. An engine was modified to measure the oil supply rate to a con-rod, big-end bearing. Then the effects of the oil supply rate on bearing temperatures and the contact between ajournal and a bearing were investigated in order to analyze lubrication characteristics. The bearing temperatures increased in accordance with reduced oil supply rate. On the other hand, the contact frequency hardly changed under almost all conditions, but steeply increased near one-third of the standard oil supply rate at the highest speed of 5000 rpm in the experiments. The results show that the reduced oil supply rate decreases the cooling effect but the hydrodynamic lubrication was sufficiently achieved except the above-mentioned severe condition. From the observation using a transparent bearing and a theoretical calculation, the reason of the above results was estimated that the oil flowing out of the bearing ends is sucked again into the bearing near a cavitation region.
Mr Revhead wrote:Fivebob, you make some good points there.... i'll read that lot after work....
blacktops dont rev any higher. and yes when oil levels kept topped up, and under normal use then there isnt a problem with them.
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
