****heavy duty 4age turbo clutch****
Postby stefegg89 » Tue Mar 31, 2009 7:22 pm
i have a 4agze bigport with td05 and a t50gearbox..
its at speed tech getting tuned at the mo the clutch is slipping on it when goin for more boost i need a heavy duty clutch but i am wanting to get one small enough for the t50 gearbox
my mate had got 1 on his 4agze but its bigger and wouldnt fit on my gearbox as he has a w55
any ideas were i could go to get a clutch asap
stefegg89
Postby ~SlideWays~ » Tue Mar 31, 2009 7:31 pm
Go to MP Autoparts
28 Montgomery Cre Upper Hutt
04-526 9128
Greg will sort you out. Best option will be to modify the standard pressure plate and see what he can do for a friction plate.
He did the clutch in my old ae86 4agze with w55 and also my current 212kw 4agte with 4agze flywheel.
~SlideWays~
Postby rollaholic » Wed Apr 01, 2009 12:25 pm
you might already have one but the smallport / 20v flywheels fit inside a T50 and take a slightly bigger clutch
