Dyno sheet
Postby fivebob » Fri Apr 03, 2009 2:27 pm
Assuming the run ended at 7400 then the red 27(?)psi boost spike occured at 2800rpm, peak power is at 6600rpm and peak torque somewhere between 3500-4200rpm. All those figures seem to make sense to me.
Very impressive!!!
Postby audi man » Fri Apr 03, 2009 2:31 pm
fivebob wrote:Assuming the run ended at 7400 then the red 27(?)psi boost spike occured at 2800rpm, peak power is at 6600rpm and peak torque somewhere between 3500-4200rpm. All those figures seem to make sense to me.
Very impressive!!!
Next time i get a dyno done i get it in rpms would make more sence then.
1.5 jz mk3 supra,675rwkws at 28psi and 723rwkws at 32psi
audi man
Postby strx7 » Fri Apr 03, 2009 2:33 pm
So i go back to my original statement.
if you are at 2800rpm at 100kph, the dyno sheet finishes at 5320rpm, you make peak torque between 2500 and 3000rpm and peak hp at 4760rpm
unless you've got VVTi and some VERY interesting cams I cant see that being possible
Postby strx7 » Fri Apr 03, 2009 2:43 pm
Those numbers make sense but they aren't what he's telling us
Postby audi man » Fri Apr 03, 2009 2:49 pm
I will have to go back to torque to get it in rpms but as you can see on the dyno sheet in red i get full boost around 73kms thats about 1800rpm, on the runs he had done he as not hit the rev limiter so shutting off befor 7000rpms
audi man
Postby strx7 » Fri Apr 03, 2009 2:51 pm
I'm very interested as it would appear that your set up would make a interesting super saloon engine package.
I'm assuming its not a VVTi engine?
Postby audi man » Fri Apr 03, 2009 2:54 pm
strx7 wrote:I'm very interested as it would appear that your set up would make a interesting super saloon engine package.
no not vvti engine, i can alwas build you a engine with the same specks as mine,
audi man
Postby strx7 » Fri Apr 03, 2009 3:04 pm
VVTi on top of that package would give an VERY interesting torque curve.
I have a blue printed & Balance 2JZ bottom end which i will be putting a worked VVTi JZGE head on at some stage in the future (may take a couple of years)
Postby audi man » Fri Apr 03, 2009 3:07 pm
strx7 wrote:VVTi on top of that package would give an VERY interesting torque curve.
I already have a sper already worked none vvti 1jz head,
audi man
Postby Lith » Fri Apr 03, 2009 3:10 pm
What displacement is this engine? I really can't see a 3litre doing the things you are saying.
2007 Mazdaspeed Axela
Lith
Postby audi man » Fri Apr 03, 2009 3:20 pm
Lith wrote:What displacement is this engine? I really can't see a 3litre doing the things you are saying.
The displacement is 3068cc if that helps
audi man
Postby Lith » Fri Apr 03, 2009 3:23 pm
Without Nitrous Oxide? :?
Lith
Postby audi man » Fri Apr 03, 2009 3:23 pm
Lith wrote:Without Nitrous Oxide? :?
yes with out nos
audi man
Postby audi man » Fri Apr 03, 2009 3:25 pm
yes with out nos
the nos shot i do have only makes 20kws so would only be a 50hp shot
audi man
Postby Lith » Fri Apr 03, 2009 3:54 pm
Haha I have seen what a 50-75hp shot does to a 3litre engine running a 1000hp turbo on it before 8O
This is a dyno plot of an RB30DET with a slightly larger turbo than yours run without NOS, then the start of one where a similar shot to what you have is squirted into it where it prompted busted into wheelspin lol
Boost curve with NOS looks much like yours, if you have managed to do that without NOS then omfg.
Lith
Postby audi man » Fri Apr 03, 2009 4:26 pm
Lith wrote:Haha I have seen what a 50-75hp shot does to a 3litre engine running a 1000hp turbo on it before 8O
With this new head i have now my boost just so quick, but even with my old set up i still had fast spooll up, that dyno sheet you have there do you know it thats race gas, that the sort of power if not more i am looking for, for next season.
audi man
Postby audi man » Fri Apr 03, 2009 4:30 pm
With this new head i have, the boost just so quick, but even with my old set up i still had fast spooll up, that dyno sheet you have there do you know it thats race gas, that the sort of power if not more i am looking for, for next season.
audi man
Postby Lith » Fri Apr 03, 2009 4:32 pm
Yeah that one is a with race gas more to illustrate the NOS difference, but it has a pretty safe pump gas tune:
With race gas and 30psi the dyno never held the power properly, it seems anything over 900hp @ wheels it seems it would start letting go :(
Lith
Postby audi man » Fri Apr 03, 2009 4:35 pm
Lith wrote:Yeah that one is with race gas, but it has a pretty safe pump gas tune:
Thats nice power if thats on pump gas, do you know what gear box that is.
audi man
Postby Lith » Fri Apr 03, 2009 4:42 pm
PPG gearset in an R34 GTR gearbox, AWD - yeah definitely pump gas... the full power race tune was much more impressive, was over 700kw @ wheels on 30psi before traction issues on the dyno started kicking in. Car ran once with the H-pattern box on NZ soil without nitrous, did a 9.7 tapping the revlimiter in each gear and then blew the PPG gearbox - never to run again on our soil :(
Full weight street legal R34 GTR!
Lith
Users browsing this forum: No registered users and 59 guests
