Trying to diagnose a problem on a VVT TT supra.
Happened suddenly during driving, noticed when going to acelerate.
Symptoms are
Idle is fine
But try to free rev it and missing/hessitation upon initial rev, if you accelerate more, intially it will hold
and miss (meaning it wont rev past a certain rpm) then after a second or so it will rev up ok.
Its also intermitant in the sense that sometimes its not as bad as others (think heat factor).
If it does clear up and you load it (eg boost) it will miss badly and not provide much boost if any.
You start to hear the turbos spooling as if a hose has come off.
I checked all hoses, seem fine (didnt go too much into detail).
Tried checking error codes, it has an E1 but no T1 or TE1 terminal
(well socket is there but no wire coming to it), so i shorted it with E1 and Ts
Now there are about 5 lights flashing.
Engine Light shows an 8 and a 9.
The ABS light shows 41, 51 and 78
Checked MAP Sensor, Air flow Sensor and TPS connections, all sweet.
Oh also couldnt get it to reset, tried removing efi fuses and then removed battery for 10 mins each. But didnt make any difference.
Maybe this ecu version needs a computer to plug in and clear it ??
Any ideas ?
