Caldina Owners!
Postby sergei » Sat Apr 11, 2009 12:31 pm
probably slider seized up.
You could probably clean it up and will be fine, otherwise it will cause uneven wear on the pads.
Postby cat007 » Sat Apr 11, 2009 12:34 pm
what do you mean by movement?
Postby snwtoy » Sat Apr 11, 2009 12:47 pm
bs wrote:One thing I would like to know, is if all rear brakes on the caldina's are as in the photo below, with only the one bolt as such. Photo is of left rear brake.
Both rears are the same. And the left rear one has movement in it when no brakes are on and when the hand brake is on, but is solid when the brake pedal is pushed down. The right rear dosen't have any movement. Any idea's as to why this might be?
Yes, they have one bolt and one slider, yours is normal.
Handbrake is in the drum in the centre of the hub, and doesn't use the calliper which means the calliper may still move slightly even if the handbrake is on.
snwtoy
Postby bs » Sat Apr 11, 2009 1:45 pm
cat007 wrote:what do you mean by movement?
I can move it side to side with my hand :?
Sweet. So how does one clean up the slider?
Reason I came accross this is that the brakes are squeaking on the left hand side.[/quote]
bs
Postby snwtoy » Sat Apr 11, 2009 2:19 pm
When you take the bolt out, lift the caliper up, then slide it off the slider. I'm no expert on these, but I had to do my rear pads a couple of months ago. You can also remove the caliper bracket (slider pin is a part of this) (two fairly easy access bolts behind the hub).
I cleaned stuff up with some brakekleen (spray on drip off) and some turps on a rag. Waited for it to dry then put new grease on the slider and reassembled.
For what it's worth, on the left side the pads were 25% worn, while on the right they were 75% worn... maybe it's a common thing?
snwtoy
Postby AJz » Sat Apr 11, 2009 10:09 pm
ma hoewagon
jk, lol
old pic, before teins
I had vtax :(
AJz
Postby 99gtt » Sun Apr 12, 2009 11:16 am
snwtoy wrote:When you take the bolt out, lift the caliper up, then slide it off the slider. I'm no expert on these, but I had to do my rear pads a couple of months ago. You can also remove the caliper bracket (slider pin is a part of this) (two fairly easy access bolts behind the hub).
same thing on my caldina just cleaned it all up is all good now
SOON TO BE 500 HP
99gtt
Postby bs » Sun Apr 12, 2009 7:17 pm
Sweet! Thanks guy's. Will attack it tomorrow :D
bs
