4age twin carb ignition setup needed
Postby D0DGEE » Mon Apr 13, 2009 10:38 pm
did a search and didnt find much just wondering what and where to get one as the one in a mates car keeps blowing the after market ignitor setup he has had for ages was going to see if there any factory options to try
D0DGEE
Postby jakesae101 » Mon Apr 13, 2009 10:42 pm
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Re: 4age twin carb ignition setup needed
Postby matt dunn » Mon Apr 13, 2009 11:19 pm
D0DGEE wrote:did a search and didnt find much just wondering what and where to get one as the one in a mates car keeps blowing the after market ignitor setup he has had for ages was going to see if there any factory options to try
Not really, all adapted aftermarket stuff.
If he has one that is cooking igniters, best bet is to fix it,
My bet would be that he is not using heat transfer paste under the module and/or the heatsink is not big enough.
Matt
Postby D0DGEE » Mon Apr 13, 2009 11:34 pm
its one of the hyperpak ones he been thur about 3 so he said and i cant see why so was going to try another style as he just wants it going now heard there some place which mods 4k dizzys to work
D0DGEE
Postby matt dunn » Tue Apr 14, 2009 12:55 am
D0DGEE wrote:its one of the hyperpak ones he been thur about 3 so he said and i cant see why so was going to try another style as he just wants it going now heard there some place which mods 4k dizzys to work
Have seen that done and it is quite common, there is the two types,
ones with an internal and external module.
Postby ChaosAD » Tue Apr 14, 2009 6:22 pm
What about using the stock 4age ecu??
ChaosAD
Postby shihad » Thu Apr 16, 2009 11:22 am
im currently THINKING about selling my 4age carb setup it made 92kwatw (must be a high reading dyno) pretty much under 5grand lol
getting bottled by the friendly Oamaru locals for not doing skids - Coupe Life
shihad
Postby Dell'Orto » Thu Apr 16, 2009 1:44 pm
ChaosAD wrote:What about using the stock 4age ecu??
Would probably pack a hissy fit without any sort of injection signal.
Postby NZ_AE86 » Tue Apr 21, 2009 5:35 pm
You can use the factory ecu/dizzy/sensors and run it that way. You will get a much nicer engine that way as the ign advance will be right. You will need to run a TPS on your carbs.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
