Blacktop full of crap under rocker cover
Postby l1ttle_d3vil » Wed Apr 15, 2009 8:58 pm
Just being emailed these pics of a newly purchased corolla wagon, running a 4AGE Blacktop. Done around 180,000km from memory...
Any idea what it would be from? and whats the best way to clean it off?
Postby jakesae101 » Wed Apr 15, 2009 8:59 pm
wholy crap has it ever been serviced?
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby xsspeed » Wed Apr 15, 2009 9:07 pm
If thats just whats under the rocker cover then... 8O
Postby Twolitre » Wed Apr 15, 2009 9:08 pm
How can anyone neglect something so poorly? I bet it reflects in other aspects of their life too.
If that was my car I'd remove the head and get it cleaned out by an engine builder or just go straight to a second hand engine. The rest of the engine has prob suffered too as a result and the sump would also need removing and cleaning.
Twolitre
Postby jondee86 » Wed Apr 15, 2009 9:12 pm
Thats the WhaleOil camshaft anti-scuff lubricant that is used at the
factory for break in. Looks as so the lid fell off the can when they put
that engine together !!!
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby l1ttle_d3vil » Wed Apr 15, 2009 9:16 pm
jondee86 wrote:Thats the WhaleOil camshaft anti-scuff lubricant that is used at the factory for break in. Looks as so the lid fell off the can when they put that engine together !!!
are you bored again, or being serious? :? car is running fine, this was just noticed while doing an oil change etc...
ive read 20v's get a oily-buildup due to failed pcv valve or something, but thats on the TB's and i'd imagine it wuold only be a fine buildup, nothing this bad?!
Postby frost » Wed Apr 15, 2009 9:44 pm
theres two ways to go about this.
1, leave it alone and act like its not there :P like you said its running fine now
2, complete tear down and acid bath for about 3 times. block and head. (that's how long it took to clean my blacktop head)
what ever you do DON'T be tempted to try and clean it out your self, or you'll block up the oil pickup and fuk the motor.
this happens because in japan. they never service there cheap runarounds. they have so much faith in the quality of the toyota name that they assume it will never die. so just top up the oil when needed.
also the blacktop suffers from the sludge build up worse then any other motor ever made. (if not serviced)
Postby l1ttle_d3vil » Wed Apr 15, 2009 9:48 pm
^^exactly what i told him, apparently its quite hard/caked on too, so would easily block any oil galleries. not causing problems right now, so why fix it :lol:
Postby Bling » Wed Apr 15, 2009 9:56 pm
For lols do an engine flush :lol:
Did you need to grab a new seal for the cam cover or is it rubber? Keen to know what mines like, but not if I have to replace the seal.
Postby johndoe1025 » Wed Apr 15, 2009 9:57 pm
and i thought my blacktop was bad, mine had about half that when i took the head off....that needs a bath ASAP. and some oil flush might do the bottom end enough? not sure. needs attention though. dont blacktops have squirters aswell? :?
johndoe1025
Postby jakesae101 » Wed Apr 15, 2009 10:04 pm
i wouldnt recomend engine flush it will losen the crap and put it into oil galleries and oil pickups ect
jakesae101
Postby Bling » Wed Apr 15, 2009 10:09 pm
johndoe1025 I was only joking, it would mean instant death....
'lols'
Postby sergei » Wed Apr 15, 2009 10:32 pm
Strip the engine apart, remove sump remove cams, remove buckets etc, remove all seals, remove head, buy shitloads of paint stripper, soak the engine, head and all affected metal parts in it for prolong period. Get all new seals, as originals will be hard as rock.
Or get another second hand engine.
This happens when people skip oil changes on regular basis (also includes regular distance oil changes and lots of idling traffic, or million 2 min. trips.)
Postby Stott69 » Wed Apr 15, 2009 11:19 pm
yea as sergei said, thats awesomely nasty to look at.
Luke: my blacktops a rubber seal, but be careful when you put it back together, make sure seal is in the groves in the cover and head, if its not it will leak like a sieve. I drove from palmy to waioru and lost 1L of oil, fixed next morn before driving home tho
Image jzs147 Aristo money pit
Stott69
Postby jondee86 » Thu Apr 16, 2009 12:22 am
Hey... if the engine was running OK, the best thing to do is just do
several oil changes with cheap oil. Drain it, fill it up with fresh, and run
it until the oil is nice and black (won't take long). Drain it and fill it with
fresh, and run it... etc... etc.
If you run engine flush you will shake so much crap loose that you will
block the pickup and galleries. Cheap oil just acts like a weak solvent
and breaks the crap down gradually.
Cheers... jondee86
jondee86
Postby Lloyd » Thu Apr 16, 2009 12:43 am
As said, lack of servicing. Certain oils are worse for doing it than others.
If you really want to get rid of it then remove rocker cover and sump, and waterblast the hell out of everything. Likely only get some of it off. Best bet (if you can be bothered) is remove the head and get it cleaned properly. I'd be getting the sump off and making sure the pickup is clean. Have had to clean up a 4E with insides just like that which had the engine light flicking on from a blocked pickup.
My old silvertop head looked just like that too. Heaps and heaps of build up that you just about had to chisel off. Quick bath at the reconditioners and it looked like this...
Postby cat007 » Thu Apr 16, 2009 9:54 am
My mates 1600 mazda engine he imported looked like that too
they just never service their vehicles lol
Postby rollaholic » Thu Apr 16, 2009 1:20 pm
SERVICE YOUR CARS KIDS
Postby RS13 » Thu Apr 16, 2009 2:41 pm
I had a Pulsar that looked like that under the covers, gave it an oil change, poked around at the sludge a bit, cleaned up as much as possible.. was driving around the next day, the oil light flickered on, drove it home (I have little to no mechanical sympathy for sub $1500 cars!), ended up stripping the sump off, pickup was clogged almost solid! Cleaned it out, had no worries at all after that! :)
RS13
Postby gleem » Thu Apr 16, 2009 2:57 pm
i had that on my blacktop. i degreased it with spray on degreaser as mych as possible and then gosed of. then i left it in a bath of proper degreaser/water mix and it came out perfect. head was of ofcoarse
gleem
