MAGN1T wrote:Sergei, you seem to have problems getting most things to work.
Steve
MAGN1T wrote:
Anybody who relies on google ends up filling their heads with rubbish.
MAGN1T wrote:The sensor has only 2 wires.
If they are the wrong way round , it won't work. Reversing the wires will probably fix it.
It is an output only,one way, you can't send a signal into it from the ecu.
Maybe you'd like to explain how bore size comes into it when knock occurs close to TDC and the only measurement of relevence is the combustion chamber volume, or the shortest distance across it.
Steve
MAGN1T wrote:Anybody who relies on google ends up filling their heads with rubbish.
MAGN1T wrote:Maybe you'd like to explain how bore size comes into it when knock occurs close to TDC and the only measurement of relevence is the combustion chamber volume, or the shortest distance across it
MAGN1T wrote:You can get to the moon and back on 48K. If you want to digitise a 4KHz signal you need a clock frequency of 8KHz.
It's all the other rubbish that takes up processing power.
sergei wrote:Do you deny that if I use 3SGE sensor in my 3SGTE it will not work?
Or if I use 4AGZE sensor in my 4AGE?
Mr Revhead wrote:now now ppl, play nice![]()
Mr Revhead wrote:laying out your theories and ideas with actual figures and examples is good, and lets others work out who is right or not for them selves
Two types of remote sensor are being used today: tuned and broadband. Tuned or resonant sensors are used in many low-end knock detection systems. Either mechanically or electronically, the sensor amplifies the magnitude of the signal in the frequency range of the knock-excited resonance (sometimes called the fundamental frequency). A limitation to this approach is that a different sensor can be required for each engine type, due to variations in the characteristic frequency. The resulting part number proliferation increases overall system costs for the manufacturer. To eliminate the cost penalty, sensor bandwidth can be made wide enough to encompass all expected variations in the fundamental frequency. However, doing so can possibly decrease system performance.
When engine knock occurs, a shock wave is generated inside the combustion chamber. The shock wave excites a characteristic frequency in the engine, which is typically in the 5 kHz–7 kHz range. Cylinder bore diameter and combustion chamber temperature are the main variables that affect this fundamental frequency. Variations in the fundamental frequency for a given engine configuration can be as much as ± 400 Hz. Larger diameters and/or lower temperatures result in a lower fundamental frequency.
Mr Revhead wrote:sergei and fivebob are very good with electronics (not saying magn1t isnt)
sergei wrote:EDIT2: Oh here is the problem:
http://www.toyodiy.com/parts/p_J_1991_T ... l?hl=89615
fivebob wrote:sergei wrote:EDIT2: Oh here is the problem:
Funnily enough all those sensors listed will work on any of the SW20 ECUs, so I would assume it's the same for ST185s. I know because, after changing the connector, I've used a Gen III sensor on a early Gen II ECU and had no problems.
frost wrote:ok so i get that the bore of the engine/size/density determines the knock frequency. so what if i have over bored my 4age block to 82mm.
1. would i need to recalibrate a new knock sensor for the new frequency?
seeing as there so narrow band.
