by barryogen » Fri Nov 07, 2008 9:50 pm
to deecee
I'm pretty sure that there is/was a beams 3sge in FWD format already, only single vvti, on the intake side.
If meaning putting the normally RWD beams into a fwd format, I've heard that there are issues with oil starvation or something because it is sitting on a different angle than it was originally or something.
to tech128
I've seen one, and heard of a few, traction is an issue, but I don't see how it couldn't be fun.
There are guys slapping turbo kits on Altezzas, and they have higher compression ratio, and more vvti stuff to deal with. If keeping it low boost, something like an emanage should be able to take care of retarding timing, and adding more fuel.
