INJECTORS 20v 4a
INJECTORS 20v 4a
Postby ke_25 » Fri Apr 24, 2009 4:16 pm
Hey
looking at getting soe bigger injectors for 4age blacktop,
and was going to try and retain to use the factory rail to save making up a new fuel rail with extrusion etc,
just contacted redline and there a various sid efeed injector listings, and was wondering which engines you know fit into teh 20v rail?
looking for around teh 800cc mark.
Cheers Shaun
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby sergei » Fri Apr 24, 2009 4:32 pm
3rd gen 3SGTE might fit
Postby TRD_ZERO » Fri Apr 24, 2009 5:32 pm
They do but they are only 550.
Previous:
TRD_ZERO
Postby sergei » Fri Apr 24, 2009 5:49 pm
TRD_ZERO wrote:They do but they are only 550.
Only?
What sort of power is he aiming?
550 is well enough for 200-250 kw.
EDIT: Ahh stupid me, didn't RTFP, he is after 800cc....
Postby AceSniper » Fri Apr 24, 2009 6:31 pm
sard do them, 3sgte, 1jzgte, 2jzgte vvti
AceSniper
Postby gasman » Fri Apr 24, 2009 7:20 pm
sarf 800cc, $225 each from redline
"What can possibly go wrong?"
gasman
Postby frost » Fri Apr 24, 2009 10:29 pm
bloody hell 800cc for a blacktop. how much boost are you going to run?
Postby matt dunn » Fri Apr 24, 2009 10:48 pm
I ran 550's now run the 800's
The 550's are a bit small if you want to do too much,
I was at the limit on them with my 1600 motor.
and the 800's are probably too big, as still lots left in them at 500hp,
but they dont seem to have idle problems, so their being too big does not seem to be a problem.
Postby rollaholic » Fri Apr 24, 2009 10:50 pm
frost wrote:how much boost are you going to run?
ahh... all of it, i think
Postby ke_25 » Sat Apr 25, 2009 2:05 am
AceSniper wrote:sard do them, 3sgte, 1jzgte, 2jzgte vvti
do they have to be vvti? teh ones on redline suit 1j/ej20t and 2j/ej20t?... any help. just dont wnat to get the wrong ones, as could be expensive mistake!!
ke_25
Postby ke_25 » Sat Apr 25, 2009 2:06 am
frost wrote:bloody hell 800cc for a blacktop. how much boost are you going to run?
yeah i want to push a descent amount of boost, black has been build with ross pistons and spool rods etc, so want to see what i can get out of it. wont be massive power, only runnign a gt2871r, but yeah just dont want to falk out and have to buy more injectors later.
ke_25
Postby AceSniper » Sat Apr 25, 2009 12:02 pm
what part numbers have you been given?
SARD 800cc Injector 63564
(Injectors) ¥9,384 (Sale) ¥8,663
Side feed, high impedance. 2 hole. Lag time: 1.6msec.
AceSniper
Postby AceSniper » Sat Apr 25, 2009 12:04 pm
8663 yen + shipping prob be cheaper than redline?
http://www.greenline.jp/catalogue/bccat ... ory=engine
AceSniper
Postby TRD_ZERO » Sat Apr 25, 2009 12:20 pm
Classic!! :lol:
Previous:
TRD_ZERO
Postby ke_25 » Sat Apr 25, 2009 12:39 pm
yeah i can get for around 205inc from redline for the ones from a 1j.
ke_25
Postby matt dunn » Sat Apr 25, 2009 12:44 pm
1jz and 2jz non vvt ones fit straight into the 20V,
