Interchangable Diff output CV Cups?
Postby CelicaGT8 » Sun Apr 26, 2009 11:45 pm
Interchangable Diff output CV Cups? i have no idea if thats what you would call them, but i tryed....
Trying to put a G series diff into a Celica rear subframe. does anyone no if there is a Cv cuppy thing like showen below that fits into a g series diff but only have 4 studs like the celica one? The celica one measures about 83mm from stud to stud (middle)
CelicaGT8
Postby strx7 » Mon Apr 27, 2009 8:57 am
Drive Flange is there technical term i would have thought. you can interchange them if......
seal size is the same and spline length/diameter/position is the same
Postby Burning Angel » Mon Apr 27, 2009 6:20 pm
another possibility is to make an adapter plate similar to wheel spacers that change stud pattern.
like this:
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby fangsport » Mon Apr 27, 2009 7:08 pm
strx7 wrote:Drive Flange is there technical term i would have thought. you can interchange them if......
or an appropriate seal can be sourced if the spline count and length is the same
fangsport
Postby CelicaGT8 » Mon Apr 27, 2009 7:35 pm
But does anyone no of a 4 stud supra drive flange?
CelicaGT8
Postby matt dunn » Mon Apr 27, 2009 7:40 pm
CelicaGT8 wrote:But does anyone no of a 4 stud supra drive flange?
We converted a JZA80 diff head into a Mazda S5 rear end and modified the flanges to suit the mazda axel's,
dont think we have any pictures of it,
but was a new flange made and welded onto the old stubs.
Postby CelicaGT8 » Tue Apr 28, 2009 5:48 pm
Gess il have to make my own then.... dam supras
CelicaGT8
Postby 85AW20v » Thu Apr 30, 2009 9:47 pm
Going by your avatar it's something like D-cups you're wanting :D
Sorry - couldn't resist it!!
See ya
Simon
85 MR2 20v
85AW20v
Postby CelicaGT8 » Fri May 01, 2009 1:16 am
No - for g seires.... G cups :D
CelicaGT8
