The flange is no more than 90 degree's against flow and about 200mm down stream from the TB, has a good vacume sorce, ive tried changing the spring.
it's on a rb20det with 16psi running t3t4 type turbo, any help will be appreciated.
cogent wrote:the legit tial springs show up on trademe frequently for cheap, that might be an option if you didnt want to $&#$% around with the spring in there.
http://www.trademe.co.nz/Browse/SearchR ... omAll=True
"damn how you get it so low?'
"chops all round bro even in the 'gate"
rollaholic wrote:didnt the centre come out of one of yours matt, and end up jammed in an intake runner or something similar? or am i thinking of the wrong person
