Blacktop 20V - Cold Air Intake or Panel Filter?
Postby Kittah » Tue May 05, 2009 8:10 pm
I hear a lot of people scrapping the idea of pod filters on the Blacktop 20V. Is it worth making up a cold air intake with pod filter, or would something along the lines of an Apexi panel filter replacement be as suitable?
Kittah
Postby Bling » Tue May 05, 2009 8:52 pm
The reason pods get hassles is that no one builds an air box around them. If you can be bothered, build a box/intake that means only cold air from the front of the car can get to the pod.
Easier option is to as you say just get a panel filter. K&N / whatever.
Use the search button for ideas.
Postby sergei » Tue May 05, 2009 9:28 pm
Keep the air box.
Postby Kittah » Tue May 05, 2009 10:00 pm
sergei wrote:Keep the air box.
Why do you suggest that?
Kittah
Postby sergei » Tue May 05, 2009 10:27 pm
Because with stock everything even well designed cold air intake will not have any gains, you will get only losses as toyota did a very good job on standard air box and tuned the ECU to work with it.
Length, volume and resonator chamber plays important role.
Unless you are going with cams/ecu/headers there is no point doing anything to air intake on a 20v.
From my own experiment, the power went from 80is kw to 67kw atw by fitting a poddie.
Postby Kittah » Tue May 05, 2009 10:28 pm
Cheers for that :D
So if I'm going with headers and exhaust, will it be worthwhile at that point, or is still not worth playing with until I get into tuning and the like?
Kittah
Postby sergei » Tue May 05, 2009 10:29 pm
Kittah wrote:Cheers for that :D
So if I'm going with headers and exhaust, will it be worthwhile at that point?
Not unless you are getting programmable ECU.
Postby Kittah » Tue May 05, 2009 10:31 pm
Very quick reply, even before I edited it! I guess that answers my question then, and I shall be simply buying an Apexi Power Intake panel filter :)
Kittah
Postby Mr Revhead » Tue May 05, 2009 11:10 pm
sergei has it covered
K&N would be my choice, but i'v never seen one of those apexi ones. im just not a fan of Japanese performance filters as a large amount of them tent to be crap!
Postby Emperor » Tue May 05, 2009 11:13 pm
Yeah.. Toyota spent alot of time and money in the R&D to design the airbox. Not for someone to stick a pod there instead or they would of done that factory?
Emperor
Postby Mr Revhead » Tue May 05, 2009 11:15 pm
well, factory also has to consider noise!
Postby levinguy » Tue May 05, 2009 11:52 pm
i'm torn between taking the pod off my blacktop and going back to a standard airbox, and taking the plenum off and putting filter socks on the trumpets.
half the power, but the noise it makes!.... :oops: :P
levinguy
Postby Bling » Wed May 06, 2009 1:01 am
Yeah tends to detonate a bit with socks though, so unless you back the timing off thats probably half the reason you lose power.
The sound is awesome though I agree. I've had pod / open trumpets / k&n panel. Pod was average, you have it for noise and the open trumpets are WAY better. So its either open trumpets or panel filter imo :lol:
I've been running a k&n panel for ages now and won't be changing back.
Postby Kittah » Wed May 06, 2009 1:16 am
Cheers guys, awesome help here :)
I'm going with Apexi really for three reasons. Firstly I'm a JDM whore, secondly I've read at least two test articles where Apexi came out on top, and three I don't like the idea of having to oil my air filter. I'm just too lazy to remember to oil a K&N :lol:
Dropped a question into Fortyone and received the answer for which part I need, so I'm going ahead. Cheers guys 8)
Kittah
Postby MR2BOY23 » Wed May 06, 2009 8:58 am
My pod filter melted in my silvertop, keep the box :D
You could also try a fram airhog panel filter, theyre even better than k&n
MR2BOY23
Postby jetshin » Wed May 06, 2009 9:34 am
Here's something I did which cost me hardly anything and improved performance a little (although might placebo :lol:) . inlet connects to some ducting which leads to the factory airbox.
jetshin
Postby MR2BOY23 » Wed May 06, 2009 9:39 am
^^ That looks really cool
MR2BOY23
Postby Kittah » Wed May 06, 2009 10:01 am
MR2BOY23 wrote:^^ That looks really cool
+1 on that! When I get around to giving my car a Facelift makeover I'll definitely do something like that. Very slick 8)
Kittah
Postby Eddy1612 » Wed May 06, 2009 11:56 am
you're one of those characters that belive that toyota makes every car perfect. :D
FYI most car makers dont make cars perfect on purpose.
a. it protects their higher model cars so that they can justifiably ask more money for.
b. it protects their own performance brand eg TRD Nismo etc (+ plus courteous to others)
c. if toyota was putting the best research into every car they made then they would have price tags closer to R35 GTR
yes i think headers and a decent exhaust (no bigger than 2.5" on your car needed) would net some power and torque gains.
As for the Pod filter that is a matter of cold air. Pod or cone filters can tend to make you lose power if it simply has to suck hot air because the extra flow is compromised because of this. If you select a good brand pod filter (apexi is good) and design a good way to access cold air then you will get a small power increase. (no need to change your ecu)
Eddy1612
Postby Quirky » Wed May 06, 2009 2:20 pm
I put a pod filter on my 4agze and got 98kw.
I then put the original air box back in and got 105kw ATW.
Hur hur awesome :)
Both filters were of the K&N, and bonnet closed.
Just go with the panel filter, if my results are anything to go by, unless you are enclosing the pod filter, its useless.
Hello There
Quirky
