4bid1n 2jz wrote:ive got 3" but dont have anything to compare it to its a bit laggy off the line if not spooled up first thats with after market turbo tho
Malcolm wrote:that seems a bit backward, I would think it would be better to have the cooler (and therefore lower volume) air flowing through the smaller pipe. When you say you gained 20kw, what was the previous system?
blitza wrote: but that big finned thing will slow flow down, so surely the larger diameter is required after the intercooler to keep the same flow rate?
Py7h0n wrote:John was using 2.5" till he changed his I/C a couple of years ago, now he's 3" and 500rwkw+.
2.5" will do up to around the 400wkw mark.
Malcolm wrote:I would think it would be better to have the cooler (and therefore lower volume) air flowing through the smaller pipe
Users browsing this forum: Bing [Bot] and 4 guests
