DriftSpecStarlet wrote:But its a known fact that Piston 1 has the great probability in Detonation with the factory computer being so sh*t at accepting modifications to the engine that it nails the bearings
sergei wrote:I don't think there is problem with big ends on 3S. There is problem with poor maintenance.
Akane wrote:DriftSpecStarlet wrote:But its a known fact that Piston 1 has the great probability in Detonation with the factory computer being so sh*t at accepting modifications to the engine that it nails the bearings
It's cylinder 2 and 3, due to the intake manifold being unable to distrubute intake air evenly.
For a start it's usually piston #2 or 3 that has the problems, and secondly the factory computer is pretty good at accepting modifications, with the Gen II computer being slightly better than the Gen III in that respect due to the use of an afm rather than a map sensor.DriftSpecStarlet wrote:But its a known fact that Piston 1 has the great probability in Detonation with the factory computer being so sh*t at accepting modifications to the engine that it nails the bearings
iOnic wrote: they do it because they have a less than average sump that allows oil to move away from the pickup without too much encouragement - especially in MR2's (more centrifugal force, oil pushed to one side, knock knock - who's there?). The gen3's onwards are better for it with the Gen4's having a properly baffled sump. But no wet sumped engine is immune to oil starvation.
fivebob wrote:...................but alas no, and the urban legend of 3S bearing problems is born
levinguy wrote:hand experience
kim0663 wrote:On my car, when the oil level gets low, when you start it in the morning, it has this certain characteristic. It's usually due for a oil change as well when i feel that 'characteristic'.
strx7 wrote:Akane wrote:DriftSpecStarlet wrote:But its a known fact that Piston 1 has the great probability in Detonation with the factory computer being so sh*t at accepting modifications to the engine that it nails the bearings
the the way the block flows coolant around number 3
