Akane wrote:How can the argument only go one way?
Simple really. I said static flow has little to do with real world flow, that's easily proven if you bother to do the calculations using wave theory.
As I said the argument that it gets better or not is an entirely different one. We're talking about a functioning
system not an isolated component. There are many things that affect the volume of charge entering a cylinder, static flow of the intake manifold is only one of them, and IMHO a very minor one.
You're saying it could only get better in real world running engine situations, due to this 4-6psi per cycle fluctuations, show us the data?
Nope, never said that it got better, only that the flow bench numbers tell you little if anything about what happens inside a running engine system. You should realise that cylinder scavenging of the entire system has more to do with how the charge volume enters/exits the cylinder and the interaction of all systems components, rather than static flow measurement of one isolated component.
I'm not seeing as much blown up Gen 3's as there is Gen 2's (actually I havn't seen/read/heard any Gen 3's cylinder 2/3 failures), mainly due to the lesser sample size of the said engine, there's a lot less Gen 3's than Gen 2's out there as well. Argument invalid? you tell me, all I see is dead Gen 2's, havn't seen dead gen 3's yet due to said problem.
Then you haven't been looking, or your memory is very poor. I have two first hand examples, one blown Gen III and one Gen IV, both blown #2 pistons, though there were also broken ringlands in #3 and in one case #4 pistons, but by far the worst was #2. I know of several other Gen III & Gen IV piston failures that are the same.
I do recall a member of mr2oc (Yes the people you dislike)
That's extremely pretentious, and ill-informed, of you judging whether or not I dislike some people. I have no dislike for any members of MR2OC. I guess you just don't really understand how to form an unbiased judgement of the facts.
did the 4xEGT probe test, as close to the cylinder head as possible with the same distance as possible to each other, they recorded a 50F to 100F differences on a mildy tuned Gen 2, that's a lotta temp difference and it could mean just barely made it or a blown up engine, which is a lot more than your said 1-2% +/-
If it’s the example I’m thinking of the probes were far from equidistant and even if they were, how do you explain a 10% difference in EGT from only a 2-3% difference in flow???
You might not be a big fan of EGT but EGT is directly proportional to A/F ratio, they go hand in hand like yourself and your ability to find random car data.
Actually the relationship is not as linear as you imply and in fact past stoich the temp will probably go down not up.
If cylinder 2/3 problem is that much related to exhaust manifold, I'm sure people would've been much better off with custom exhaust manifolds, but the truth is they're just as proune to blow things up as the next guy.
References please!!!
Besides which I didn’t say it was related to the exhaust manifold either, just that the exhaust manifold layout has a greater influence on cylinder scavenging than some supposed static flow imbalance in the intake manifold.
fivebob wrote:How much is "that much"???
It doesn't take that much increase in cylinder temp to make one cylinder more prone to detonation.
Exactly, that 50F ~ 100F difference is all it takes as I've stated above, pretty crazy stuff huh?
Not really that crazy, and also not proof that the cylinders are running leaner, just that they may be running hotter. You still haven’t provided references so we can check out the validity of the claimed difference for ourselves
So.. What is exactly your reasoning behind why this is all happening? Because after reading all these posts, I still have no idea which camp you're at.
I’m not in any camp, well none of the ones you’ve mentioned anyway. I have my theories but until I get a chance to put them to the test I’ll keep them to myself.
Suffice it to say that it’s not as black and white as you maintain. i.e. The intake manifold imbalance is not the sole cause of the problem, IMO it plays a very small part, if any in the #2/3 piston failure mode evidenced in 3S-GTE engines. Like I said before if it was the only cause then you would expect to see different failure modes in Gen III & Gen IV engines, but you do not.
Educate us.
Educate yourselves. It’s much more satisfying than being told the answer
