Sun visor clashes with roll cage.
Postby Rick » Fri May 22, 2009 7:03 pm
I have got a problem where the factory sun visor mounting position clashes with the roll bar, how have people got around this without mounting the visor below the bar as this blocks my vision?
Postby Emperor » Fri May 22, 2009 7:16 pm
make a bracket to mount it on the bar?
Emperor
Postby Leon » Fri May 22, 2009 7:17 pm
Make holes in visor, attach in suitable location (permanently located) with cable ties.
Postby strx7 » Fri May 22, 2009 9:28 pm
paint strip or sticker banner type set up across top of windscreen
Postby Rick » Fri May 22, 2009 11:07 pm
strx7 wrote:paint strip or sticker banner type set up across top of windscreen
And that will pass a WOF?
Postby IH8TEC » Fri May 22, 2009 11:19 pm
full cage (obviously) and motorsport liscence make any difference to that? normally aloud to bottom of where visor is std anyway
Postby Bling » Fri May 22, 2009 11:38 pm
^^ Speaks the truth
Postby strx7 » Sat May 23, 2009 8:46 am
in both my cars wth cages the visors fit but must but only permenantly down, when dad had his fiat, we just painted a black strip across the top of the screen to the height the sunvisors came down to, passed wof's no issues at all.
Postby Mr Revhead » Sat May 23, 2009 10:23 am
i would ask the man who will be doing your WOF's as i bet you can find WOF guys who would be ok with it, and others who wouldnt be....
Postby Leon » Sat May 23, 2009 10:27 am
IH8TEC wrote:full cage (obviously) and motorsport liscence make any difference to that?
No
Postby RedMist » Sat May 23, 2009 1:34 pm
I've heard of compeditors temporarily mounting the visors for WOF then removing them again.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Rick » Sat May 23, 2009 1:42 pm
Mr Revhead wrote:i would ask the man who will be doing your WOF's as i bet you can find WOF guys who would be ok with it, and others who wouldnt be....
I have phoned several reputable WOF testing stations and they all said they wouldn't pass a car that only has a painted strip or sticker banner across the top of windscreen.
So I will have to make up something to hang the visor off, somehow..
Postby strx7 » Sat May 23, 2009 2:21 pm
Testing stations or warrant issueing garages?
I'd just about bet most testing stations wouldn't pass a motorsport car simply because they wouldn't understand all the ins and outs of certification and Motorsport Authority Card.
Postby pc » Sat May 23, 2009 4:28 pm
I go to Upper Hutt VTNZ for my WOFs on all my cars... funnily enough I have the least problem with the race car... probably cos it's gets the most maintenance :lol:
Just make something that does what a sun visor is intended to do, and it will pass.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby 85AW20v » Sat May 23, 2009 10:25 pm
Check out the visors on an MX5. They're sort of three sections and fold up into one piece about 40mm wide. You might find room to mount them in front of the top rollbar.
See ya
Simon
85 MR2 20v
85AW20v
Postby Distrb » Sat May 23, 2009 11:58 pm
I just cable tie mine to the rollcage bar running across the top of the windscreen when i go for a wof.
then cut the cable ties when i get home afterwards, and put them back in the cupboard
Distrb
Regular Poster
Postby Mr Revhead » Sun May 24, 2009 2:35 am
sorry, put them back where? :lol:
Postby Distrb » Sun May 24, 2009 1:45 pm
On the bench till i could be f**ked putting them back in the starlet shaped cupboard :lol:
Distrb
Regular Poster
Postby Boost_4_Life » Mon May 25, 2009 10:28 am
ive just got mine cable tied to the rollcage, works fine.
you should get one of those funky pull down blinds like buses have :lol:
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby Loudtoy » Tue May 26, 2009 7:42 pm
Boost_4_Life wrote:ive just got mine cable tied to the rollcage, works fine.
I have funky pull down blinds in my lounge - but that might be different because the lounge only moves when the tanker goes past with a full load 8O .
On a different note i just cable tie mine to the roll cage, have a hook cable ties to a different point on the roll cage that the visors can hang on when not in use and remove the whole lot when it's not wof time.
Seems to work ok with the vtnz guys - altho they always ask where the cert plate is for the cage then wonder why i'm handing them my authority card. 1st time through i had a god argument with them about authoity cards and cert plates, was quite funny for the 1st 10 minutes or so
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Users browsing this forum: Bing [Bot], Google [Bot] and 20 guests
