Time's getting on for the 1st and I've got no brakes
the fallen303 wrote:just relax man, he's doing us a good deal on them, he'll get them done when he can. i know that you would have liked to have them on and going by june, but as the old cheese ad goes, good things take time.
Py7h0n wrote:If you need to get ahold of him talk to me.
Bazda wrote:You prob could have got the brackets laser cut!
Thats how we do most of ours. Make a template with holes in it from thin steel (or even wood) then get the proper one made to the correct thickness.
btw i'll only be running 193kw at pukekohe![]()
cat007 wrote:
and great things happen instantly
is that what you tell the mrs?
cat007 wrote:Bazda wrote:You prob could have got the brackets laser cut!
Well I have no idea how he's doing them - but I have to get the brakes on the car and get the new brake lines measured up - hence the urgency lol
193kw? WHY?
Bazda wrote:
You should of just come see me about the brakes. I would of just told you how to make up a wooden template.
193kw was on a different dyno. We only used it for tuning, didnt really care about the power output. I measure the output when I drive it hahaha and its def still got around 270kw at this boost level.
