fivebob, there is 26 wires.
strx7, i had a look and i see whats going on. cheers for that i overlooked it thinking the pressure release valve was in the cover.
i'll stick to the alloy sump and mod the pan.
frost wrote:fivebob, there is 26 wires.
fivebob wrote:frost wrote:fivebob, there is 26 wires.
Which means it's a loom for an Auto ECU. Manual looms only have 14 wires on that connector.
Engine end of the loom should have a few spare plugs hanging of it that would go to the transmission.
speedracer07 wrote:actually after a conversation I had last night with a mechanic I'm thinking the issue I'm having where it goes full rich when the car is engine braking (off throttle, in gear, high vacuum) is probably due to the auto ECU.
