strx7 wrote:I know of alternators which bolt straight onto the Y series motor you just need to change the wiring plug, they are around 70-90 amp. because you have 2 batteries in it, i wouldn't think that warrants putting in a bigger alternator, its all down to how much current draw everything running at once has. What have you got in it to require 2 batteries anyway?
It's a campervan. The main battery will power the starter motor and ignition where-as the deep cycle battery will power everything else, lights, stereo, inverter, fridge, water pump etc etc
The idea being, even if I leave a light on or leave the fridge on overnight or anything like that - the next morning when I go to start the car I know that the engine is going to crank over with a fresh un-used battery (even if the other is totally drained). I have a 130 blocking diode so both batteries are able to be charged from the 1 alternator - but neither can draw power from the other....
Do you know more details about these alternators? A 90 amp one would be great!
Hunt
