Sump modifying......
Postby 3T-Rona » Thu Jul 02, 2009 7:48 am
Hey looks like i may need to mod the sump to allow the 1uz to sit low enough in the LN61, any suggestions?
Should i make a whole new sump or should i cut out the piece that fouls and remould it?
help..... cheers
Joseph
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby frost » Thu Jul 02, 2009 5:54 pm
what sump do you have? there is a few to choose from. my mates hilux uz sits quite nice as it is. bonnet close has about 2 inch clearance.
i'll find out if its the front sump model as that would make sense and fitting easier.
Postby evil_si » Thu Jul 02, 2009 6:34 pm
ive done both.
all depends on how much needs removing,
for my ute im currently making a new sump so it can sit as low as possible due to the body drop,
the last conversion i did i managed to notch the back of the sump 25mm successfully to give enough clearance
evil_si
Postby deaf_rattle » Thu Jul 02, 2009 6:36 pm
yeah, as mentioned there are 3 to choose from.
otherwise id use the sump you have and get that modified to suit, but thats alot of work.
while you are at it, id look at getting the sump at least winged, if not extra baffling. seems people are running the bearings on the 1uz's probably due to insufficent oil and baffling.
check out my build thread to see what we did to my sump..
Postby 3T-Rona » Thu Jul 02, 2009 9:02 pm
its a front sump.
looks as tho the rear could be cut and flipped and re-welded,
may just make up a new one, would ally be better than stainless for heat distribution?
cheers for opinions
Joseph
3T-Rona
Postby frost » Fri Jul 03, 2009 12:59 am
alloy will crack next to the welds if you hit something.
steel will bend and hopefully save you from oil loss.
i;m just using mild steel same to the sump.
Postby strx7 » Fri Jul 03, 2009 7:49 am
go for extra oil capacity while you're at it. When I did the new sump for my 2jz Surf 5 litres of oil would only just show on the tip of the dipstick.
Postby 3T-Rona » Fri Jul 03, 2009 11:13 am
sweet as may have up just make a new one and modify the oil pickup, make it run wider than long more capacity....
i dont really plan on hitting anything, but i will take than into consideration,
will have a big bash plate also...
Cheers guys
Joseph
3T-Rona
Postby frost » Fri Jul 03, 2009 3:40 pm
my comment about hitting stuff is only intended if your driving on new zealand roads :lol:
Postby 3T-Rona » Fri Jul 03, 2009 7:43 pm
haha fair enough,
looks like starting from scratch will be the easiest option.
What would you suggest regarding baffles, plates down the centre wth holes or solid plates going from one end to the other with a gap, kind of like a maze?
3T-Rona
Postby deaf_rattle » Sat Jul 04, 2009 9:41 am
thats what i had done to mine.
wings for extra capacity and trap doors to stop too much sloshing around corners.
Postby Crucible » Sat Jul 04, 2009 5:49 pm
deaf_rattle wrote: Image
thats a good idea with the hinges!, never seen that before
Crucible
Real Life Mechanic
Postby 3T-Rona » Sat Jul 04, 2009 11:59 pm
sorry deaf rattle, i did check out your thread on your build just forgot to mention it. you didnt really coment on what u did on the sump, but looks good. 1UZ sumps are a little different to the older style but its all relative i guess
Will be getting an outline of the original sump mountings and going from there.
Cheers guys
3T-Rona
Postby Bazda » Wed Jul 08, 2009 1:03 pm
I don't really see how that sump would stop oil surge. Having the hinges there... its just like not having the wings on the side, its mainly for more oil so it can just recirculate back around in the sump.
But isnt the problem oil surge? you need horizontal baffles to stop that.
At present if you turn a long corner hard the oil will just ride up the side of the sump, or backwards etc.
Postby deaf_rattle » Wed Jul 08, 2009 3:49 pm
the wings and hinges are there to make sure there is plenty of oil around the oil pick up at all times, around corners especially.
Postby Bazda » Wed Jul 08, 2009 4:10 pm
deaf_rattle wrote:the wings and hinges are there to make sure there is plenty of oil around the oil pick up at all times, around corners especially.
It needs some sort of covered section, hard to explain lol
Postby deaf_rattle » Wed Jul 08, 2009 4:23 pm
maybe if you roll the car, but i dont plan on doing that.
if i do, oil will probably be the least of my worries.
i know what you mean and i did think about that. could always put something in like that later, but i dont think thats as important as extra capacity and the hinges we have put in.
http://www.seight.com/baffle.html
some info there
