Which (if any) Toyotas have an electric vacuum pump?
Postby Nova » Sun Jul 05, 2009 7:34 pm
I am looking for the vacuum pump to run a brake booster on a diesel, and heard that possibly MR2 and Estima/Emina vans have an electric pump?
Any truth to the rumours, and if so, how much are they?
Cheers.
Nova
Postby strx7 » Sun Jul 05, 2009 9:21 pm
Hmm, cant say I've heard of this one before, but i'd be interested to know.
Postby matt dunn » Sun Jul 05, 2009 9:56 pm
dont think so,
diesil alternators have vacuum pumps, and some vehicles have a specific belt driven pump, but never heard of an electric one??
Postby neo » Sun Jul 05, 2009 11:55 pm
Simplest thing to do will be to get an external vacuum pump destined for a mini, the 1275GT's had em...
Image http://www.minispares.com/Product.aspx?ty=pb&pid=38542
Image http://www.trademe.co.nz/Trade-Me-Motor ... 035193.htm
my bad, I realise your after the vacuum pump side, not the booster side :(
neo
Postby the fallen303 » Mon Jul 06, 2009 10:22 am
twin turbo jzs147 aristo's run a electronic/nitrogen brake booster if that helps. my uncle was looking at using one on a kit car at one point...
true house of JZ
Stay true to the origin
the fallen303
Postby KwS » Mon Jul 06, 2009 1:02 pm
good point about the mr2..... i know ones with power steer use an electric pump for that, but do they run a vacuum line all the way up to the front for the brake booster, or is it indeed electric?
KwS
Postby fivebob » Mon Jul 06, 2009 1:09 pm
KwS wrote:good point about the mr2..... i know ones with power steer use an electric pump for that, but do they run a vacuum line all the way up to the front for the brake booster, or is it indeed electric?
They run a line to the front, early turbos had a one way valve built into the booster, later they changed that to having one in line.
Postby Py7h0n » Mon Jul 06, 2009 5:24 pm
Don't go anywhere near that system!! My old man just had the one in his car replaced after failing completely (2002 Lexus GS300) - Try $2900!!
the fallen303 wrote:twin turbo jzs147 aristo's run a electronic/nitrogen brake booster if that helps. my uncle was looking at using one on a kit car at one point...
Py7h0n
Postby Rob » Thu Jul 16, 2009 9:22 pm
The late lucida diesels have a vacum pump on the rocker cover which is run off the cam by an arm on a lobe. Early ones still have a front pump on the alternator
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby strx7 » Thu Jul 16, 2009 10:14 pm
Rob wrote:The late lucida diesels have a vacum pump on the rocker cover which is run off the cam by an arm on a lobe. Early ones still have a front pump on the alternator
its still by no means electronics
