deaf_rattle wrote:i think most people run the exchanger and pump from the w2a i/c legacies.
usually plenty at pick a part.
thegreatestben wrote:And buying from frozen boost just isn't an option, I'd be looking at close to $300 just for the pump, If I was gonna spend a bit I'd get a davies craig pump
strx7 wrote:thegreatestben wrote:And buying from frozen boost just isn't an option, I'd be looking at close to $300 just for the pump, If I was gonna spend a bit I'd get a davies craig pump
At the end of the day, you get what you pay for, pay peanuts expect monkey results. Fork out some $$$ and get the results to go with it
XS1V wrote:Im running Subaru pre rad and pump with ST205 I/C in my ST185 rally car and it works well. Will swap pre rads with you if you want though
Brad
Mr Revhead wrote:my understanding is that the cooling effect is caused by heat transfer
if the water is flowing too fast it doesnt have the time to absorb as much heat as it would if it was flowing slower.
however in thinking about it, faster flow may mean the water absorbs less, but more is flowing by so maybe it balances out....
if thats the case then flow rate isnt really that critical, as long as the water doesnt get past its most efficiant cooling temp
end of the day, i still think there is nothing wrong with the subaru pumps and rad!
imo the pumps rep for failing is due to where its mounted in stock applications, ie more heat. maybe.
Stealer Of Souls wrote:Well. I personally can't understand you can pump the water too fast, but I'm no expert. I'd like to know how it works (just out of interest).
On pumps, I've been running an EWP80 on my cooling system for some time now. No issues, goes great.
So if you've got the money, it's something to look at.
