what injectors work? 3sgte
Postby lucasthefallen » Sun Jul 05, 2009 11:22 pm
looking to upgrade to 500cc+, after some suggestions as to what injectors will work with little or no modification and other standard vehicles. so far i only know about the later 3sgte 540's that will go in.... any others? anyone know about Rx7 550cc ones?
lucas
Need Service or Repair work done? send me a PM
lucasthefallen
Postby ke_25 » Sun Jul 05, 2009 11:58 pm
prty suree 1j and 2j vvti ones also work as just purchased some sard ones for these that fit 20v 4a, which also suit 3sgte
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby Akane » Mon Jul 06, 2009 2:49 am
USDM 2JZ-GTE indigo top works. I have a set for sale. PM me if needed.
Postby iOnic » Mon Jul 06, 2009 12:43 pm
Gen 3 3S-GTE and USDM 2JZ-GTE are the only 500cc+ injectors that drop into the factory rail and use the factory wiring.
RX7 850cc injectors fit the stock rail as well with slight modification
Postby ROBODISCO_20v » Thu Jul 09, 2009 2:43 pm
ROBODISCO_20v
Postby iOnic » Thu Jul 09, 2009 2:45 pm
Those won't fit an SW20 Turbo fuel rail and $750 is a lot to pay for injectors that flow less than JZA80/SW20 Gen3 items that can all be picked up for half that and are a direct "drop in" fitment.
Postby tsoob » Mon Jul 13, 2009 10:59 am
use evo ones 550cc
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby iOnic » Mon Jul 13, 2009 11:32 am
iOnic wrote:Gen 3 3S-GTE and USDM 2JZ-GTE are the only 500cc+ injectors that drop into the factory rail and use the factory wiring.
Evo injectors don't fit 3SGTE fuel rails...They're top fed
Postby tsoob » Mon Jul 13, 2009 6:19 pm
my bad just the number 550 popped into my head.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby Prymal » Tue Jul 14, 2009 8:32 pm
what rail are you using? and for what engine
gen2 3sgte rail + gen3 540cc's work but the rail itself is a problem - it doesnt carry enough volume for bigger flow ..
You will need to rebore , duel feed , or adust accordingly ..
Prymal
