cat007 wrote:Stealer Of Souls wrote:Well. I personally can't understand you can pump the water too fast, but I'm no expert. I'd like to know how it works (just out of interest).
On pumps, I've been running an EWP80 on my cooling system for some time now. No issues, goes great.
So if you've got the money, it's something to look at.
the faster the water flows, the less chance it has to absorb any heat. Much like the inside of an intercooler - there should be pressure drop, that way you know the intake air has had a chance to touch the cooler parts of the intercooler.
Pressure drop has nothing to do with heat transfer.
Pressure drop is a side effect to greater surface area.
With heat exchanger, the more water molecules hit the hot walls (actually the molecules/atoms from hot walls hit the water molecules) the better the cooling. Flow one would think would increase the rate of such impacts.
Heat is just the velocity of the molecules relative to the mean speed of the substance.
Heat transfer in case of heat exchanger is when vibrating molecule of the hot wall transfers the kinetic energy to the water molecule. Unless the water moving close to speed of sound in water (and is cavitating), you should not have problem with "lots of flow".
Also the bigger the difference in temperature, the faster is heat transfer, and with constant flow, you cannot saturate (where there is almost no temperature difference between the hot and cold) local water reserve.
