Dopamean wrote:I've heard Tama Autos is good (West Auckland) but they are geared towards performance rather than standard stuff, I could be wrong though..
Dopamean wrote:Update.......
They saw the light or read this post![]()
Hi Daniel attached is the EPC of cam gear the cam followers are $55.04 each +gst from TNZ and shims $9.31each theses are ex Japan
We will need to remove cam shafts to replace followers this will take 2.5 hours to do this
They have attached the EPC and it looks correct.
Thanks again, with your input or the information I've gained from this forum I wouldn't have been able to second guess what they were telling me.
Bazda cheers dude but I'll probably get them to finish the job now because they have pulled there heads out of the sand.
Mr Revhead wrote:yeah why would you need to replace the lifters? a reshim I can understand. but not a lifter, unless the shim fell out (bloody unlikely) and damaged one.
Didnt you say the noise started suddenly? instead of gradually?
a gradual increase as things wear is beleivable
a sudden increase would point to a failure of some sort.
A shim dropping out would also most likely result ina dropped valve very soon after.
If you are still happy for them to do the work, they should remove the cam cover to look and confirm the fault. actaully they should have done that as step one.....
im still of the opinion you should stay the hell away from them
Mr Revhead wrote:lucky!
Mr Revhead wrote:im still of the opinion you should stay the hell away from them
Dopamean wrote:Mr Revhead wrote:im still of the opinion you should stay the hell away from them
I'll probably book into Bazdas old mans shop.
Get a second opinion.
They did remove the rocket cover and said there was no signs of wear.
Its totally got my knickers in a twist now.
Last three days the noise has gone to almost nothing…….
Dunno where that would leave me with Toyota.
I was only suggestiing to them what the noise sounded like to me - tappets.
I'm lost....
