deaf_rattle wrote:My orbital battery went flat and i have had it on charge for the last couple of days. The battery charger always shows charging and the "charged" light hasnt come on.
Tested battery with multi meter and i got 11.93volts
is this ok? or is my battery on its way out?
BZG|Bling wrote:Just as a side note... its amazing what people will pay on trademe. That same charger is cheaper new @ Kmart
classique71 wrote:try to get your hands on a ctek charger - multi 7000 if possible
This is what i use to charge my oddyessy gel cell ..
the charger seems a bit weak , and may have issues cycling up a deep cycle battery like the one you have
deaf_rattle wrote:
yeah thats true, i might have to put it into a car and take it for a drive.
B1NZ wrote:BZG|Bling wrote:Just as a side note... its amazing what people will pay on trademe. That same charger is cheaper new @ Kmart
how muchy at k-mart?
matt dunn wrote:
On a side note, the new calcium batteries wont charge form the car if they get flat enough,
if you leave the lights on and flatten it, jump start it and drive the length of NZ, it wont be charged.
That is causing a lot of issue's.
matt dunn wrote:On a side note, the new calcium batteries won't charge from the car if they
get flat enough. If you leave the lights on and flatten it, jump start it and
drive the length of NZ, it wont be charged. That is causing a lot of issue's.
jondee86 wrote:Sooooo...... how do you charge them then ??
Cheers... jondee86
