Adydas wrote:i can check at work but there is a unit ideal for this design.. its used commonly on boats and i priced one to a customer all of 6 weeks ago..
$175 if i recall right but its a device that allows useable power on a boat via a 12v system but cuts off so there is sufficent power left in the batterys to restart the boat so you never get left with a flat battery.
Maybe this can help?
matt dunn wrote:
A VSR or voltage switching relay,
much better than a blocking diode, but does the same thing.
His question is,
I have fitted that part, now what?
It's not that easy as all the systems are intergrated inot the same loom and power source,
but my suggestion would be, ( rather complicated though)
Find the main cable that goes to the starter motor,
run that to the starting battery and everything else to the house battery.
Fit a relay to the starting circuit,
power in from start battery, power out to starter,
relay coil in from the key or old start feed.
relay coil out to earth.
Needs the relay so that a flat house battery will have enough current to bring the starter in.
Not the best situation bay far,
petrol or diesil, as you may need to do similar with the coil/pump.
79rolla wrote:may also need fule pump and ecu if youv got them
t0ms wrote:be careful with the diodes.......
if you try and charge a flat battery like you just have your alternator could be poking anything from 30 - 80 amps into it through whatever sized diode. if its not big enough its going to get reall really hot and likely to cause so major damage....
VSR is prob the safest and cleanest way to achieve what you want.
cat007 wrote:Thanks for such an insightful response!
If a lead acid deep cycle bayterr is 105amp hour rated. Does that mean at 50amps it would take 2 hours to charge?
sergei wrote:cat007 wrote:Thanks for such an insightful response!
Nope, there is charging efficiency as well, what would happen is that some current will be lost as heat.
What they mean is usually 5A load will last 21 hours (10A load will last less than half of time and so on, as higher the current less efficient the battery)
