kramer2202 wrote:Hey just wandering if any one has put bigger cc injectors on a N/A black top and if it would be worth doing to a worked black top to help get more power?
AceSniper wrote:stock ones should be fine.
I use 380cc? from a 1jzgte, but stock ones only maxout in the high rpm
Quirky wrote:standard blacktop is 8500 rev limit, so somewhere there
BZG|Bling wrote:Quirky wrote:standard blacktop is 8500 rev limit, so somewhere there
LOL got proof?
Maybe you got a limited spec one as every other standard blacktop cuts at around the 7800 mark.
Dell'Orto wrote:Dont blacktops redline at 8?
XSVWGN wrote:my brothers silvertop trueno reved out to 10000;) With the ignition in the trueno you can slowly turn the key around to off (from engine running) vey very slowly and it will turn off the eletrics and rev limiters but the engine will still run. You can hear it go past 7,8,9000rpm!!! its insane!
Not good for the engine clearly but the trueno is a piece of sh*t so gets a good thrashing!! As the engine were originally designed by Yamaha with moterbike essentials inmind i believe these things can rev out very far
Im sure someone will correct me if i am wrong...
Matt
