strx7 wrote:could be worn crownwheel teeth in the diff itself. Does it only whine while under load, no whine when you lift of and it starts to engine brake?
l1ttle_d3vil wrote:strx7 wrote:could be worn crownwheel teeth in the diff itself. Does it only whine while under load, no whine when you lift of and it starts to engine brake?
If I'm cruising at 100km and lift off completely, its silent.
If I give it throttle - even if its just enough to hold a steady speed - it will start whining.
frost wrote:maybe the lash was not properly set when it was shimmed up.
