by evil_si » Tue Jul 28, 2009 8:33 am
run a new supply line from the tank, use the efi hose either rubber all the way or use some steel tube and join it,
i reakon the ke30 fuel line would be sweet as a return,
does it have 2 lines from the tank at the moment or just 1? its been years since i played with a ke30
return hose (after the fuel reg) doesnt need to be efi hose as it doesnt have to withstand the same pressure as the supply, from the fuel rail to the reg it must be efi hose,
