ke35 injection converstion
Postby 79rolla » Thu Jul 23, 2009 5:45 pm
OK im putting my 2tgeu (+turbo now) into my ke35
iv already purchased a fuel pump and some new fuel injection rubber hoes, im guessing i am going to need to run a return line as well tho? is there particular piping i need to use? and whats the easiest way to plumb it back into the tank?
past: AE82 FXGT
79rolla
Postby 79rolla » Thu Jul 23, 2009 5:58 pm
an idea just occured
can i just use the fuel line from my 30 parts car as the return line?
past: AE82 FXGT
79rolla
Postby jakesae101 » Thu Jul 23, 2009 5:59 pm
no you need efi hose carbs run at 4psi efi is 40psi
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Re: ke35 injection converstion
Postby xsspeed » Thu Jul 23, 2009 6:00 pm
79rolla wrote:
iv already purchased some new fuel injection rubber hoes
Postby 79rolla » Thu Jul 23, 2009 6:02 pm
was told standard line would be fine, just need to replace all the rubber joiners? cant remember if that was the cert guy or a mechanic tho
past: AE82 FXGT
79rolla
Postby xsspeed » Thu Jul 23, 2009 6:08 pm
sorry I assumed that meant you had bought efi hose,
you should really buy that, as I can't see a certifier saying your engine transplant is ok if you are still using original hose
Postby l1ttle_d3vil » Thu Jul 23, 2009 6:52 pm
for the 4age i use the original feeder line as the return line because its small.
the new feeder line for the injected engine needs to be alot bigger, use 3/8 or 10mm bundy tube, bend it up yourself and use the plastic pclips or something similar to attach it to the floor.
Postby Burning Angel » Thu Jul 23, 2009 8:22 pm
depends on the power you want to make. id say in most cases 3/8" would only be used after 500-600hp. plenty of factory efi cars running 5/16" making good power.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby 79rolla » Thu Jul 23, 2009 8:31 pm
not looking for huge power atm (or probably ever from this configuration) if want to make power ill upgrade the fuel lines but not planing to get it to that level (expechily with standard internals) :roll:
past: AE82 FXGT
79rolla
Postby 79rolla » Fri Jul 24, 2009 10:25 am
oh yeah, i guess im going to need to get a fuel regulator? (and something better then the ball tap in the ute :roll: )
past: AE82 FXGT
79rolla
Postby Rob » Mon Jul 27, 2009 11:16 pm
I see you wanna put a 2T in....I've got a mate with a 3TGTE sitting in pieces in his garage which he would be keen to get sell at the right price
If your keen let me know your number and I can pass it on too him
Rob
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby 79rolla » Mon Jul 27, 2009 11:58 pm
cheres.. ill keep that in mind, might be interested in it in the future. cant relly afford it atm, just want to get it on the road and its a freshly rebult engin that i dont want to wast
but thanks ill see what happens further down the track. :wink:
past: AE82 FXGT
79rolla
Postby evil_si » Tue Jul 28, 2009 8:33 am
run a new supply line from the tank, use the efi hose either rubber all the way or use some steel tube and join it,
i reakon the ke30 fuel line would be sweet as a return,
does it have 2 lines from the tank at the moment or just 1? its been years since i played with a ke30
return hose (after the fuel reg) doesnt need to be efi hose as it doesnt have to withstand the same pressure as the supply, from the fuel rail to the reg it must be efi hose,
evil_si
Postby 79rolla » Tue Jul 28, 2009 11:24 am
its just got one line at the moment
so i should use a bigger line for a feed?
and what is a decent but low cost regulator?
cheres
past: AE82 FXGT
79rolla
Postby 79rolla » Tue Jul 28, 2009 11:33 am
oh yeah, i am likely to be using sr20det gtir injectors as well, so really should upgrade fuel line to suit shouldn't i?
past: AE82 FXGT
79rolla
