Fan switch
Fan switch
Postby Rob » Thu Jul 23, 2009 9:06 pm
Anyone out there got a schematic diagram for 20v blacktop?
My fan runs constantly since I checked my air filter (odd I know but the loom attaches to the side of the filter box) and suspect a broken conductor
Cheers for any help
Rob
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby Mr Revhead » Thu Jul 23, 2009 11:00 pm
keep an eye on the email in your sig.....
Postby AceSniper » Fri Jul 24, 2009 9:32 pm
Do you still have a/c?
Below in the pic the sensor in red is a temp switch for the fan, remove it and use a jumper wire to ground the pin in the plug, if the fan turns off you need a new temp switch.... if it keeps running could be the pressure switch in the a/c line below the coil.
the wire runs from temp switch, to the a/c pressure switch to the relay box, no feed on the wire the fan will run, to turn the fan off wire needs a neg(-)
AceSniper
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
