GTT mirror demister diagram.. fivebob?
Postby cedwards » Sun Jul 26, 2009 5:53 pm
Mirror demister's keep blowing their fuse in 98 GTT, It doesn't happen instantly but within a week she'll stop working.
Wondering if any awesome peron has a wiring diagram for me to browse..
And if possible a even more awesome person could suggest any potential weakpoints I could investigate.
Thankyou
cedwards
Postby fivebob » Sun Jul 26, 2009 7:55 pm
Wiring diagram won't be of much use to you and there's no diagnostic info in the workshop manual that I can find.
Wiring consists of Battery->Fuse->Relay->Mirror Heaters->Earth. The only thing I can suggest is measuring the resistance of the heater elements, wires should be Red-Black (power in) & White Black(earth)
Postby Stu- » Mon Jul 27, 2009 1:39 pm
Oooh Fivebob,
Would you have any info on the 110v outlet circuit? Mine's gone dead for some reason and the rear 12v doesn't work either. Fuses are ok thou...
Project Thread
Stu-
Postby fivebob » Mon Jul 27, 2009 2:03 pm
No info in the manual other than a wiring diagram which shows fuse->relay->inverter/Rear socket.
Maybe a problem with the relay?
Postby Mr.Phreak » Mon Jul 27, 2009 2:08 pm
Stu- wrote:Oooh Fivebob,
I'm assuming the switch under the dash in on?
Mr.Phreak
Postby Stu- » Mon Jul 27, 2009 2:26 pm
Haha yep
Project Thread
Stu-
Postby cedwards » Tue Jul 28, 2009 11:41 am
Many thanks fivebob.
Looks like i'll have to have a play,
The only problem with measuring the resistances is that the short is intermittent, which makes me think it may be more a exposed wire that is grounding over bumps etc,
cedwards
Postby cedwards » Tue Jul 28, 2009 11:43 am
One other question, it doesn't give the location of the relay by any chance does it??
Thanks again always appreciated!
cedwards
