Trying to swap out the cam gears on a 4agze aw11 but I have run into some problem
I removed upper timing belt cover. Turned crank pulley to TDC.
The problem I have is I can't find the two lower bolts to remove the middle timing belt cover. Therefore I can't access the tensioner.
Do I need to take out the alternator belt and crank pulley? Car is also equipped with aircon if that makes a diff.
