POP.... Big Oil Leak (Picture Update)
Postby MR2BOY23 » Fri Jul 31, 2009 12:28 am
SW20 MR2 1990
3SGE
Long night :(
Giving the car some shit tonight, was kinda low on oil and a bit of oil stabiliser revving at around 3-4000rpm. Something went pop and oil rushing out (not sure exactly where ) but just to the left of the oil filter when looking down at the engine.
No oil left its all leaked out, any ideas on what it could be Im guessing crank seal? Hoping its not that serious, any other possibilities ?
MR2BOY23
Postby Paulio » Fri Jul 31, 2009 2:26 am
Take a photo and point where the oil looks to be comming out of,
Paulio
yees booy
Paulio
Postby MR2BOY23 » Fri Jul 31, 2009 8:48 am
Yeah im gonna jack it up and take a better look soon, Ill post some pictures up
MR2BOY23
Postby iOnic » Fri Jul 31, 2009 8:54 am
Probably the oil filter seal. How long had it gone without a change? Lucky you didn't spin your bearings with the oil level low and giving it a bit of stick :P
Postby MR2BOY23 » Fri Jul 31, 2009 9:05 am
Just under 5000ks since last service, not coming from near the filter, its kinda underneath the block
Good excuse to put in the turbo engine in :P
MR2BOY23
Postby iOnic » Fri Jul 31, 2009 9:07 am
yeah time for a GTE :P Check the seal on the sump as well.
Postby KinLoud » Fri Jul 31, 2009 9:08 am
A rod probably felt like getting some fresh air!
Re: POP.... Big Oil Leak
Postby Adamal » Fri Jul 31, 2009 11:20 am
Essdub23 wrote:but just to the left of the oil filter when looking down at the engine.
Looking at it in MR2 format or FWD format? IE is it to the center of the engine or the cambelt side of the oil filter?
Has the engine ever been rebuilt? Could be one of those plugs (I forget what they're called) that are in the side of the block. If you put new ones in using something too small to knock them in, they can curve, which pulls the sidewalls of them in, and they don't stay in place properly.
Other thing it could be is the oil pressure sender.
Postby iOnic » Fri Jul 31, 2009 11:23 am
Frost plugs - if one of them went pop all he would have lost is coolant. They have nothing to do with the oil system.
Postby MR2BOY23 » Fri Jul 31, 2009 11:40 am
Side of transmission, thats where most of the oil was coming from, IM still looking for more leaks. It looks like the metal has bent outwards
MR2BOY23
Postby neo » Fri Jul 31, 2009 11:56 am
Rear main seal ? .. or a rod exited sideways 8O
neo
Postby iOnic » Fri Jul 31, 2009 11:57 am
Does the engine still turn over?
Postby MR2BOY23 » Fri Jul 31, 2009 12:26 pm
I dont wanna try and turn it over incase I damage it more
MR2BOY23
Postby iOnic » Fri Jul 31, 2009 12:29 pm
If all the oil is drained, take the sump off and check to see if anything looks abnormal on the crank/rods. Gives you a chance to look at the rear main seal as well
Postby Malcolm » Fri Jul 31, 2009 5:44 pm
put a spanner/socket on the end of the crank and rotate it, you wont do any more damage than what has already occurred, and it'll be the easiest way to see whether you've done something terrible to the rotating assembly/block or not - if you can turn it then it's probably not completely poked. Then start doing stuff like removing sump etc to find the cause
Postby Mr Revhead » Fri Jul 31, 2009 7:45 pm
is it definitely engine oil?
would be weird if it spat out the rear main
though I have seen it a coupla times before on an AE111.
unsure of the cause of that one as the guy who built the engine took the car away pretty fast! :lol:
Postby MR2BOY23 » Fri Jul 31, 2009 7:48 pm
Mr Revhead wrote:is it definitely engine oil?
Yes, 100% sure its engine oil
MR2BOY23
Postby Mr Revhead » Fri Jul 31, 2009 8:11 pm
just checking :wink: :D you dont always know what ppl know!
Postby Loudtoy » Sat Aug 01, 2009 8:53 am
While you've got the sump off, check the pressure relief setup on the oil pump - i had a car that did pretty much exactly as you describe (apart from it was full of oil) turned out the oil pump got a little bit of crap stuck in the pressure reflief valve part in the oil pump and popped what was a frost plug type setup out up near the head and just kept pumping oil out there till it was empty.
Was an easy fix once i found the problem but alot of $&#$% around finding the problem - you don't tend to check the oil pump when there's oil coming out high in the block under pressure
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby 1hypo3 » Sat Aug 01, 2009 9:30 am
If it has popped the rear main seal you could have a crankcase breathing problem check your pcv valve and hoses
1hypo3
