O2 sensor
O2 sensor
Postby tim_blair » Fri Jul 31, 2009 6:05 pm
how can you tell the difference between a wide band o2 senor and a narrow band one?
what is the dif betwen a 4-wire o2 sensor and a single wire?
tim_blair
Postby thegreatestben » Fri Jul 31, 2009 6:11 pm
More wires = heated.
Ways to tell difference between narrow and wide band = cost :lol:
thegreatestben
Postby tim_blair » Fri Jul 31, 2009 6:54 pm
i am aware that the 4-wire ones have heating
im goin to get a second hand one from pikapart for my bike project im not worried about accuracy just so that i can moniter my fuel ratio
tim_blair
Postby Py7h0n » Fri Jul 31, 2009 7:27 pm
I would never use anything from pick a part to monitor my AFR - Cheap project or not :p
Py7h0n
Postby strx7 » Fri Jul 31, 2009 10:46 pm
wideband has 5 wires or more.
3 & 4 wire sensors are heated narrow band sensors
Postby matt dunn » Fri Jul 31, 2009 10:58 pm
strx7 wrote:wideband has 5 wires or more.
Thats what I though too,
but there is a Bosch Wideband 4 wire sensor, a motorsport special.
Have fitted them to Motec dash's on NZV8 touring car for mixture logging.
But in reality most are 5 wire and expensive,
and need a controller (or ECU) to run them.
Postby 1hypo3 » Sat Aug 01, 2009 9:43 am
Toyota use "air / fuel sensors" on late model vehicles which are linear 5v wideband 4 wire sensors
the only way to be sure is to check the output voltage to the ecu as toyota also use 1v narrow oxygen sensors 4 wire also
if a vehicle is fitted with a linear sensor it is always before the cat and oxygen sensor is after the cat
Most aftermarket linear 5v sensors are 5 wire and you need a lambda controller to interpret the information
1hypo3
Postby B0000M » Sat Aug 01, 2009 10:34 am
do you know what kind of sensors ST215's have? theres a 4 wire sensor just beside the turbo
B0000M
Postby sergei » Sat Aug 01, 2009 10:39 am
B0000M wrote:do you know what kind of sensors ST215's have? theres a 4 wire sensor just beside the turbo
Narrow Band.
Postby B0000M » Sat Aug 01, 2009 10:45 am
thanks. and how do we confirm if this is working correctly - ive put my multimeter on it and found the wire that has the 0-1v range on it, and it jumps around anywhere from 0-.9v as the car idles whilst warm.
i have my doubts that it is working correctly though because the car produces black smoke when you accellerate at low revs - eg not on boost. to me this looks like its running really rich, and also if you stand near the car even at the front while its running you get that woft of smell of unburnt fuel.
is there anything else i should be checking for mixture related issues?
B0000M
Postby sergei » Sat Aug 01, 2009 11:09 am
B0000M wrote:thanks. and how do we confirm if this is working correctly - ive put my multimeter on it and found the wire that has the 0-1v range on it, and it jumps around anywhere from 0-.9v as the car idles whilst warm.
Yes it works correctly, count how many times it changes that value in 10 seconds time period, if it does 8 or more than it is fine.
As for high load conditions, the ECU generally discards current data from O2.
It will probably compensate for knock with poor fuel (do you run 98?).
Postby tim_blair » Sat Aug 01, 2009 11:17 am
thanks for the info
is there any advantage of using a 4wire instead of a 1 wire
tim_blair
Postby 1hypo3 » Sat Aug 01, 2009 11:39 am
tim_blair wrote:thanks for the info
only if youre worried about emissions the heater circuit warms the sensor faster which gives it a quicker response
1hypo3
Postby B0000M » Sat Aug 01, 2009 1:25 pm
yeah always use bp 98.
got any more ideas on things to check?
B0000M
Postby tim_blair » Sat Aug 01, 2009 6:18 pm
i just want a rough idea of what my mixture is doing
i have both a 4 wire and a 1 wire
tim_blair
Postby sergei » Sat Aug 01, 2009 6:43 pm
you mean you have both on the car?
if it is factory setup the one wire sensor is probably just a cat. overheat warning sensor .
Postby ChaosAD » Sat Aug 01, 2009 7:01 pm
You can get the bosch wideband oxy sensors as used with the innovate gear for about $120 new on trademe.
Youll need a wideband sensor controller though.
The innovate lc1 is about $350 including sensor
ChaosAD
Postby tim_blair » Sun Aug 02, 2009 11:09 pm
no no im putting 1 on my motorbike, it currently doesnt have 1
and i have one of each but want to know what is more likely to give me a better readout
tim_blair
Re: O2 sensor
Postby steve murch » Sun Aug 02, 2009 11:17 pm
tim_blair wrote:how can you tell the difference between a wide band o2 senor and a narrow band one?
the cheapest and easyist wideband youll find is on the comodore ecotech v6,it runs two of them
two wires for heater and voltage return and 0 earth,but you have to run 14.5volts to make them work or they dont give a good reading.
steve murch
Postby Leiden » Mon Aug 03, 2009 10:21 am
So the ecotech O2 is effectively a wideband oxygen sensor without the need for a wideband controller?
Is it just 4 wire? Two for heater and two for oxygen signal and oxygen signal earth?
Leiden
