Hey my ae85 had a damaged rear trailing arm bush, so I replace the lot with nolathane. Now it has something whackjob going on, I think in the rear.
It feels as if the diff moves when I lift off or accelerate on a corner. For instance the car will pull to one side, I will take the corner, feel a small lurch, then it will pull to the other side.
The new bushes were all nice and tight to put in, and visually they still seem to be fine. I cant seem to see any play with the panhard rod either when someone shakes the car.
Also seems to get axle tramp, its worst when entering my driveway which is slightly uphill. I'm not sure if its related. It is lowered with adjustables and has an adjustable panhard rod.
Does anyone have any idea what is going on? Any way it could be diff internals/axles?
